Thread Closed
further noise reduction techniques ontop of Savitzky-Golay FIR filter
Share Thread Thread Tools
Oct5-08, 12:09 PM   #1
Hi PF Designers,
Wasn't too sure if this would belong in the Electrical engineering forum but here goes.
I'm designing a prototype for my thesis that will read in sensory data wirelessly to a matlab script. This sensory data is riddled with noise, however important data is contained in the High frequency components of the signal as well.
Hence I was naturally going to use a Savitzky-Golay FIR filter in matlab. However I was wondering if I could perform further noise reduction techniques on top of this and still preserve the high frequency component that I saved.
Thoughts, dilemmas, discussion, tid bits of help?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct6-08, 05:29 AM   #2
Do you have any theoretical model?
If so there are many thechniques (e.g. kalman filter).
http://en.wikipedia.org/wiki/Kalman_filter
If not, instead of using S-golay, you can try building a specific LP filter and play with the threshold frequency
Oct6-08, 09:34 AM   #3
Recognitions:
If you know the form of your input data, then a Wiener filter will give you the theoretically optimum SNR at the output. For white Gaussian noise you can implement the optimal filter as a matched filter.
Thread Closed
Thread Tools
Similar Threads for: further noise reduction techniques ontop of Savitzky-Golay FIR filter
Thread Forum Replies
Filter out Gaussian noise from data curve Set Theory, Logic, Probability, Statistics 2
Noise Reduction System: Preemphasis/Deemphasis Filter Engineering Systems & Design 3
airbus engine noise reduction Mechanical Engineering 5
Filter to Cancel Noise Computing & Technology 1
noise reduction in a jet engine Aerospace Engineering 2
