Thread Closed
Spring Problem (Urgent)
Share Thread Thread Tools
Oct6-08, 02:59 PM   #1
Please Help some1??
To be honest I don't what to do........
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct6-08, 03:01 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Saying that you have no idea doesn't count as an attempted solution. Have you read your class notes and/or text?
Oct6-08, 03:24 PM   #3
my professor doesn't go in details and book is to consusing but still I will give a try:
attempt: First I thought to use
W = delta KE + delta PE
but I was confused b/c i did not see a way to put those spring forces in there
so i was kindly asking for a help
Oct6-08, 03:31 PM   #4
Recognitions:
Quote by dsptl View Post
Thank you for trying, your threads will generally get answered a lot quick if you show an attempted solution.
You're right to approach the problem using conservation of energy. You know that the work done by friction and the 400 N/m spring must be equal to the energy stored in the N/m spring.
Can you go from here?
Oct6-08, 03:37 PM   #5
is it like this:
F x S = Ef - Ei
Oct6-08, 03:38 PM   #6
Recognitions:
is it like this:
F x S = Ef - Ei
We'll take it a step at a time. What is the energy stored in the 200N/m spring before the block is released?
Oct6-08, 03:45 PM   #7
= .5k(x.x) + .5mv.v + mgh
Oct6-08, 03:50 PM   #8
Recognitions:
Could you explain how each of the terms arise, what does each term represent?
Oct6-08, 03:52 PM   #9
1st is spring force , 2nd is kinetic energy and 3rd is potential enery, which is 0.
Oct6-08, 03:56 PM   #10
Recognitions:
Good. What about the kinetic energy, is that non-zero before the block is released?
Oct6-08, 03:57 PM   #11
i think it is zero since Vi is 0
Oct6-08, 04:00 PM   #12
Recognitions:
Correct. So, the total energy of the system is simply the energy stored by the spring, can you calculate it?
Now, when the block reaches the 400N/m spring is compresses it. So how much energy is stored in this spring? Can you also calculate this value?
Oct6-08, 04:05 PM   #13
at intial = .5(200N/m)(.1 x .1) = 1N
at Final = .5(4000N/m)(.05 x .05) = .5 N
Oct6-08, 04:05 PM   #14
do i just add them together?
Oct6-08, 04:12 PM   #15
Recognitions:
No.
You started off with this much energy:
And ended up with this much energy:
Where did the rest of the energy go?
You also need to be careful with your units, the Newton is not a measure of energy.
Thread Closed
Thread Tools
Similar Threads for: Spring Problem (Urgent)
Thread Forum Replies
Urgent: Spring Compression Problem Introductory Physics Homework 3
Urgent Magnetic Field Problem!!! Urgent!!!!!!!!!!please Help! Introductory Physics Homework 14
forces problem(urgent urgent help needed) Introductory Physics Homework 3
Quantum Mechanics Homework Help(Urgent Urgent Urgent)! Advanced Physics Homework 3
Spring gun problem without a spring constant. Introductory Physics Homework 5
