When Do Objects Collide and Have the Same Speed?
The discussion revolves around a kinematics problem involving two objects, A and B, moving along an inclined plane. Object A starts from rest at x=0, while object B begins at x=10 m with a negative velocity. Both objects experience positive acceleration. Participants are tasked with determining the time and position of collision, as well as the time at which both objects have the same speed.
  • Participants explore equations of motion for both objects, attempting to equate their positions and solve for time. There is confusion regarding the correct time frame and adjustments needed for the equations. Some participants question the validity of their approaches and the interpretation of speed versus velocity.
The discussion is ongoing, with participants sharing their attempts and questioning the correctness of their calculations. Some guidance has been offered regarding the adjustment of time scales and the interpretation of speed, but no consensus has been reached on the solutions to the problems posed.
Participants note the complexity of the problem due to the differing starting times and initial conditions of the objects. There is an emphasis on understanding the distinction between speed and velocity, as well as the implications of acceleration on the motion of the objects.
jumbogala
Beginner's Kinematics Problem
An x-axis likes along an inclined plane, with the positive x-direction down the plane. Two objects A and B travel along the x-axis.
At t=0, object A starts at x=0 with an initial velocity of 0. At t=1s, object B starts at x=10.00 m with a velocity of -5 m/s. Both objects have an acceleration of positive 2 m/s/s.
At what time and position do the objects collide?
At what time do the objects have the same speed?
xf= x + vi(t) + 0.5at2
vf= vi+a(t)
a) Equate the two equations (because x final is the same) and solve for t.
OBJECT A: xf= 0 + (0 m/s)(tf-0 s) + 0.5(2 m/s/s)(tf-0)2
OBJECT B: xf= 10 m + (-5 m/s)(tf-1 s) + 0.5(2 m/s/s)(tf-1)2
I got t= 2.29 seconds using a graphic calculator. Is that correct? Are the equations above correct?
Part b of the question is what's REALLY confusing me. There is no time that I can find that the objects have the same speed.
OBJECT A:
vf= (0 m/s) + (2.00 m/s/s)(tf-0s)
OBJECT B:
vf= (-5 m/s/s) + (2.00 m/s/s)(tf-1s)
The two lines, when graphed, never intersect. Also, making object A's equation equal to object B's equation doesn't work either. What am I doing wrong??
vf= vi+a(t)
OBJECT A:
OBJECT B:
First of all observe that the equation for the first one released is simply:
x = 1/2*a*t2 but it starts a second earlier so, ...
x = 1/2*a*(t+1)2
The second ball then can be described as:
x = 10 -5*t +1/2*a*t2
Since we are in the same time scale (having adjusted the first equation) they will meet when x = x.
Substituting a=2 and solving for time then gives you the solution.
(t+1)2 = 10 -5*t + t2
2t + 1 = 10 - 5*t
7*t = 9
Part 2:
v = a*(t+1)
v = 5 - a* t
2*a*t = 3
4 * t = 3
Haven't I already adjusted the time scale, though, by having the (tf-1 s) part of the second equation?
EDIT: It seems that your solution is exactly one second behind my solution. How do I know which to use?
Yes, but I think you must not have been careful along the way.
See the added edit, below for part 2
Also your time scale puts the second ball leaving a second earlier I believe.
So using (tf-1 s) is not wrong? Because I tried it again and it definitely gives the answer that I originally got.
I think what's happening when you adjust for the time is that you're moving the origin so that x=0 is at x=1s. But the problem, I think is asking for the time that they collide where time was originally 0. So I think my original answer in that case might be correct?
For the second part, I think I understand the first two lines, but not the last two:
2*a*t = 4
4 * t = 4
Shouldn't I be able to equate the first two lines to find the time at which v is equal?
2*a*t = 4
4 * t = 4
Oops. You are right. My way puts the frame in terms of t=0 when the second ball is released. So yes it's 1 second too fast. Sorry for any confusion.
For the a*t terms its the same thing. But yes I set v = v then solved.
Add 1 second to that as well.
Ah okay, I think I get it now.
Except the a*t terms thing still isn't working for me. Instead of having t+1 on the first equation, it should be just t now, right? So that means on the second equation I will have to have t-1.
This should give:
OBJECT A:
vf= (0 m/s) + (2.00 m/s/s)(tf-0s) or vf=(2.00 m/s/s)(t)
OBJECT B:
vf= (-5 m/s) + (2.00 m/s/s)(tf-1s) or vf=(-5 m/s ) + (2 m/s/s)(t-1)
When equated, there is no solution!
(2t)= -7 + 2t ---> 2t-2t=-7 -----> 0=-7?
This should give:
OBJECT A:
OBJECT B:
It asks for speed being equal, not velocity.
Note I corrected a small math error in the first way I did it. 4*t = 3
But you add 1 to adjust to the same as this way. Sorry again that my simple math errors may have confused. I was just scratching them out without being careful.
Oh... I don't know how to calculate speed without giving it a positive or negative sign.
I guess I still don't understand where you got 2*a*t = 4 from, either. Sorry, I'm taking physics for the first time this year and I'm not very good at it yet =)
On the one side you have v = a*(t) = 2 t
On the other your speed starts out at 5 and slows to deceleration so = 5 - 2*(t-1)
2t = 5 - 2t +2
4 t = 7
Oh, so when the velocity is -5.00 m/s, that means the speed is 5.00 m/s.
Since the object is slowing down, however, the acceleration could be considered -2 m/s/s.
I get it now!
Thanks for all your help!
I get it now!
Cheers then.
  • · Replies 22 ·
  • · Replies 17 ·
