How Do You Calculate the Net Force on Particles in a Line with Varied Charges?
  • Thread starter Thread starter pinxzka
    Force
The discussion focuses on calculating the net force on charged particles arranged in a line, specifically three particles with charges of -67 µC, +45 µC, and -83 µC. Using Coulomb's Law, the net force on the middle particle (B) is calculated to be -0.0279 N, while the net force on the right particle (C) is -0.0052 N. The calculations involve determining the individual forces acting on each particle and summing them to find the net forces, emphasizing the importance of direction and magnitude in these calculations.
  • Coulomb's Law
  • Understanding of electric charge units (microcoulombs)
  • Basic algebra for force calculations
  • Concept of net force in physics
  • Study the application of Coulomb's Law in multi-particle systems
  • Learn about electric field concepts and their relation to forces on charges
  • Explore the implications of charge interactions in electrostatics
  • Investigate the effects of distance on force calculations in electrostatics
Students in physics, electrical engineers, and anyone interested in understanding electrostatic forces and their calculations.
pinxzka
i have a 2 specific problems, I am having trouble, if anyone can help me figure them out,
1) Three particles are placed in a line The left particle has a charge of
(-67 x 10^-6 C)
The middle partilce has a charge of (+45 x 10^-6C) and is 72cm from each of the others, and the right has a cahrge of (-83 x 10^-6)
{FIND THE NET FORCE ON MIDDLE AND RIGHT PARTICLE??) :eek:
First of all, BE SYSTEMATIC!
You must solve 2 problems:
1) Calculate the net force on the middle particle
2) Calculate net force on the right particle
i)
Before you attempt to solve either of these problems, you must clarify yourself about what is meant with "net force".
If an object is subjected to several forces at the same time (for example by interacting with other objects), the "net force" on the object is the sum of all the (individual) forces acting upon it.
ii) Now, you must consider:
What (individual) forces acts upon the middle particle?
(This will be the first step in solving problem 1))
I assume you know about Coulomb's law, which states what force a single charged particle experiences from another charged particle.
Clearly, the other particle experiences a force of equal magnitude, but opposite direction.
Now, Coulomb's law is valid for every pair of particles, and the expression for the (individual) force(s) associated with these 2 particles doesn't change a bit just because a third particle is present!
That is, if you have a system of particles, and you wish to calculate the net force on, say the first particle, you must sum together all the (individual) forces that particle experiences as being seen as a member of a pair of particles!
If you have 3 particles, and wish to calculate the force on particle 1, add together the force acting upon it from particle 2 (according to Coulomb's law stated for particles 1 and 2),
AND the force acting upon it from particle 3 (according to Coulomb's law stated for particles 1 and 3)
Write down which force acts upon which particle from which other particle like:
Force on particle 1 from particle 2: , and so on.
(Hint: For your problem, there is a total of 6 such forces, you will need only 4 of them to solve your problems)
Be particularly careful to use correct expressions for charges, distances and the direction of the forces!
To determine the net force on the middle and right particles, we need to use Coulomb's Law, which states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
First, let's label the particles as A, B, and C, with A being the left particle, B being the middle particle, and C being the right particle.
To find the net force on B, we need to find the individual forces acting on it from A and C. The force from A on B can be calculated using the formula F = k(q1q2)/r^2, where k is the Coulomb's constant (9x10^9 Nm^2/C^2), q1 is the charge of A and q2 is the charge of B, and r is the distance between them. Plugging in the values, we get:
FAB = (9x10^9)(-67x10^-6)(45x10^-6)/(0.72)^2 = -0.0125 N
Similarly, the force from C on B can be calculated as:
FCB = (9x10^9)(-83x10^-6)(45x10^-6)/(0.72)^2 = -0.0154 N
Since the forces are acting in opposite directions, we need to add them together to get the net force on B:
FBnet = FAB + FCB = (-0.0125) + (-0.0154) = -0.0279 N
Therefore, the net force on the middle particle is -0.0279 N.
To find the net force on the right particle, we can use the same process. The force from A on C can be calculated as:
FAC = (9x10^9)(-67x10^-6)(-83x10^-6)/(1.44)^2 = 0.0102 N
And the force from B on C can be calculated as:
FBC = (9x10^9)(45x10^-6)(-83x10^-6)/(0.72)^2 = -0.0154 N
Adding these two forces together, we get the net force on C:
FCnet = FAC + FBC = (0.0102) + (-0.0154) = -0.0052 N
