| Thread Closed |
Net force, force diagrams, normal force |
Share Thread | Thread Tools |
| Oct8-08, 07:43 PM | #1 |
In a problem whereby you want to calculate the net force of the rope lifting a box, and there is something in the box, whether you take into account the normal force.
The forcees would be the tension of the rope, and the weight of the box and the object inside. To caculate the net force of the rope, do you take into account the normal force? |
| Oct8-08, 08:56 PM | #2 |
| Oct8-08, 10:52 PM | #3 |
| Oct9-08, 09:04 AM | #4 |
| Oct9-08, 09:36 AM | #5 |
Mentor
Is the box resting on a surface, or suspended in mid-air? The normal force between the surface and box would be included in the calculations, since it is a force acting on the box (or box+contents).
There could also be friction present. |
| Oct10-08, 12:30 AM | #6 |
The problem is this:
a 0.250 kg block of cheese lies on the floor of a 900 kg elevator cab that is being pulled upward by a cable through distance d1 = 2.40 m and then through distance d2 = 10.5 m. (a) Through d1, if the normal force on the block from the floor has constant magnitude FN = 3.00 N, how much work is done on the cab by the force from the cable? (b) Through d2, if the work done on the cab by the (constant) force from the cable is 92.61 kJ, what is the magnitude of FN? Do you count the normal force in your calculations? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Net force, force diagrams, normal force
| How do i calculate a normal force when gravity is not the only force involved?? | Classical Physics | 4 | ||
| calculating normal force and net force of 20 kg mass going down inclined plane at... | Introductory Physics Homework | 11 | ||
| Normal Force, Friction Force, Accel problem | Introductory Physics Homework | 2 | ||
| HELP! problem involving force of friction and normal force | Introductory Physics Homework | 7 | ||
| Free body diagram involving normal force, gravitational force, and applied force. | Introductory Physics Homework | 4 | ||
