Gravitation - Satellite in circular orbit
The problem involves a satellite of mass m being launched into a circular orbit at a height equal to the radius of the Earth. The original poster is trying to determine the minimum energy required for this launch, while grappling with concepts of circular motion and gravitational forces.
  • The original poster expresses confusion about the transition from an elliptical trajectory to a circular orbit, questioning how gravitational force can provide the necessary centripetal acceleration. They also reflect on the relationship between initial and final energy in this context.
Some participants have offered guidance by suggesting a focus on energy considerations, indicating that work must be done to change the satellite's potential and kinetic energy. Others have attempted to simplify the problem by breaking it down into two steps: raising the satellite and providing it with the necessary lateral velocity. However, there is no explicit consensus on the best approach to resolve the original poster's confusion.
The original poster's understanding appears to be hindered by the complexities of orbital mechanics and the assumptions regarding the nature of the orbit. There may be constraints related to the homework guidelines that influence the discussion.
atavistic
A satellite of mass m, initially at rest on the earth, is launched into a circular orbit at a height equal to radius of the earth. What is the the minimum energy required for this purpose?
GMm/r^2 = mv^2/r
PE at surface = -GMm/R
PE at orbit = -GMm/r
where r = 2R
I am not getting the logic, and I think my problem is more so related to circular motion, I mean if we launch a satellite ,then it will go up and if viewed from outside Earth , follow an elliptical trajectory , then how does it get into a circular orbit?How does a force which is actually pulling it downward suddenly provide centripetal acceleration for rotational motion? How is the initial and final energy related. I did most of the problem but this has left me perplexed made me revisit circular motion but I didnt get the solution to my answer anywhere.
To get you on the right track, think of this in terms of energy. You need to do a certain amount of work on the satellite to get it into orbit. That work goes into a change in potential energy - and - you have to get the satellite up to a certain velocity - so you also need to provide enough energy that goes into kinetic energy.
I understand that but that's not really my question but thanks.
You are making it more difficult than it is. You don;t have to go into the technical details of the launching. And it does not have to be an elliptical orbit (unless you consider a circular orbit as a special case op ellipse).
You may think about it in two steps:
1. rise the satellite up to a height of 2r - you provide potential energy
2. "kick-it" laterally so it gets the appropriate speed for that orbit - you provide kinetic energy
Total energy provided = sum of the two.
Now, for the orbital motion, you must have mv^2/r = F
F is the centripetal force, here the gravitational force between satellite and Earth. This will give you the orbital speed.
  • · Replies 30 ·
