Thread Closed
pushing a lawnmower
Share Thread
Oct9-08, 04:37 PM   #1
pushing a lawnmower
Consider a lawnmower of weight w which can slide across a horizontal surface with a coefficient of friction [tex]\mu[/tex]. In this problem the lawnmower is pushed using a massless handle, which makes an angle theta with the horizontal. Assume that [tex]F_{h}[/tex], the force exerted by the handle, is parallel to the handle.
Take the positive x direction to be to the right and the postive y direction to be upward.
A:
Find the magnitude, [tex]F_{h}[/tex] of the force required to slide the lawnmower over the ground at constant speed by pushing the handle.
B:
The solution for [tex]F_{h}[/tex] has a singularity (that is, becomes infinitely large) at a certain angle [tex]\theta_{critical}[/tex]. For any angle [tex]\theta[/tex] > [tex]\theta_{critical}[/tex], the expression for [tex]F_{h}[/tex] will be negative. However, a negative applied force [tex]F_{h}[/tex] would reverse the direction of friction acting on the lawnmower, and thus this is not a physically acceptable solution. In fact, the increased normal force at these large angles makes the force of friction too large to move the lawnmower at all.
Find an expression for tan[tex]\theta_{critical}[/tex]
2. The attempt at a solution
okay, so i got part A fine:
fnet=0
x:
-cos[tex]\theta[/tex]*[tex]F_{h}[/tex]+[tex]F_{f}[/tex]
y:
n-sin[tex]\theta[/tex]*[tex]F_{h}[/tex]-w
multiply the y equation by [tex]\mu[/tex] to eliminate n
-cos[tex]\theta[/tex]*[tex]F_{h}[/tex]+[tex]\mu[/tex]n=[tex]\mu[/tex]n-sin[tex]\theta[/tex][tex]F_{h}[/tex][tex]\mu[/tex]
rearrange to get fh...
[tex]F_{h}[/tex]= (-[tex]\mu [/tex]w)/(-cos[tex]\theta[/tex]+sin[tex]\theta[/tex][tex]\mu[/tex])
part b i just not sure where to start..the force becomes infinite when the denominator becomes 0... but i dont know how to express that in terms of tan[tex]\theta_{critical}[/tex].
thanks for any help
lol i see now someone had the exact same question.. no answer though..here
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Oct9-08, 05:04 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by phthiriasis View Post
Hi phthiriasis! Welcome to PF!
(have a theta: θ and a mu: ΅ )
Yes, you're right …
the force becomes infinite when the denominator becomes 0 …
ie cosθcritical = ΅sinθcritical …
so tanθcritical = … ?
Oct9-08, 05:20 PM   #3
1/΅
seems so simple now... thanks tim
Thread Closed
Similar discussions for: pushing a lawnmower
Thread Forum Replies
Pushing a lawnmower. picture included Introductory Physics Homework 0
[SOLVED] The NET FORCE and a lawnmower Introductory Physics Homework 7
[SOLVED] pushing a lawnmower Introductory Physics Homework 0
Pushing Off On Ice Classical Physics 7
Guinea Pig Lawnmower General Discussion 11
