Where is the electric field is zero?
The electric field between two charges, 1.5X10^-6 C and 3.0X10^-6 C, separated by 0.2 m, is zero at approximately 0.08 m from the smaller charge. The condition for zero electric field is established when the electric field strengths from both charges are equal. Using Coulomb's law, the equation kq(1)/(x^2) - kq(2)/((0.2-x)^2) = 0 leads to a quadratic equation that can be solved for the distance x. The calculations confirm that the neutral point is indeed at 0.08 m.
  • Understanding of Coulomb's law
  • Familiarity with electric field concepts
  • Knowledge of quadratic equations
  • Basic algebraic manipulation skills
  • Study the derivation of Coulomb's law in detail
  • Learn how to apply the quadratic formula effectively
  • Explore electric field superposition principles
  • Investigate the effects of varying charge magnitudes on electric field distribution
Students in physics, electrical engineers, and anyone interested in understanding electric fields and charge interactions.
3.14159265358979
two charges of 1.5X10^-6 c and 3.0X10^-6 c are 0.2 m apart. Where is the electric field between them equal to zero?
heres what i got...
the electric field will be 0 when the field strength of the first charge minus the field strength of the second charge equals 0.
therefore,
q(1)-----x------P-------(0.2 - x)-------q(2)
where...
P is where the electric field equals 0
q(1) is the first charge
q(2) is the second charge
x is the distance (in metres) from the charge
[ kq(1) / (x)^2 ] - [ kq(2)/ ((0.2-x)^2) ] = 0
from here,
i cancel out the k's
find the common denominator and cancel it out once my numerator is expanded
try and use the quadratic equation to solve for x. however, when i try to solve for x i get a complex number...what am i doing wrong? the book says the answer is 0.08m (approx.) if you know a faster and much easier way, please do tell...thanks a bunch...
Let the neutral point be a distance r from the smaller charge Q and a distance R-r from the bigger charge 2Q. Note that
kQ/r^2 - 2kQ/(R-r)^2 = 0 expresses the neutrality of the electric force along the line between the charges, by Coulomb's law.
After some algebraic manipulation you get
r^2 + 2Rr - R^2 = 0.
Applying the quadratic formula,
r = -R +/- sqrt(2)R. (I am too lazy to figure out how to stack the plus or minus symbol, so I wrote it as +/-.)
Discard the root that does not lie between the two charges. This leaves you with
r = [sqrt(2) - 1]R.
Here R=0.2 m, so you have
r = [1.414 - 1] 0.2
which works out to about 0.08 meters, that being the distance from the smaller charge.
Your approach is correct, but it seems like you may have made a mistake in your calculations when solving for x using the quadratic equation. Here is a step-by-step solution for finding the value of x:
1. Set up the equation:
2. Cancel out the k's:
[ q(1) / (x)^2 ] - [ q(2)/ ((0.2-x)^2) ] = 0
3. Expand the denominators:
[ q(1) / x^2 ] - [ q(2) / (0.04 - 0.4x + x^2) ] = 0
4. Find the common denominator:
[ q(1)(0.04 - 0.4x + x^2) / x^2(0.04 - 0.4x + x^2) ] - [ q(2)(x^2) / x^2(0.04 - 0.4x + x^2) ] = 0
5. Simplify:
[ 0.04q(1) - 0.4q(1)x + q(1)x^2 - q(2)x^2 ] / [ x^2(0.04 - 0.4x + x^2) ] = 0
6. Combine like terms:
[ (q(1) - q(2))x^2 + 0.4q(1)x + 0.04q(1) ] / [ x^2(0.04 - 0.4x + x^2) ] = 0
7. Set the numerator equal to 0:
(q(1) - q(2))x^2 + 0.4q(1)x + 0.04q(1) = 0
8. Use the quadratic formula to solve for x:
x = [ -0.4q(1) ± √(0.4q(1))^2 - 4(q(1) - q(2))(0.04q(1)) ] / 2(q(1) - q(2))
9. Simplify:
x = [ -0.4q(1) ± √(
