What is the chemical name for OI2?
  • Thread starter Thread starter DarylMBCP
    Chemical
The discussion revolves around the chemical name for the compound OI2 and the oxidation states of Nickel. Participants explore the nomenclature of covalent compounds, particularly focusing on the naming conventions for compounds involving oxygen and iodine, as well as the oxidation states of transition metals.
  • Homework-related
  • Some participants propose that OI2 is named Oxygen diiodide, while others suggest it could be called diiodine oxide based on electronegativity considerations.
  • There is uncertainty regarding the oxidation states of Nickel, with some participants stating that Nickel(II) is the most stable oxidation state, while others mention the existence of rare alternative oxidation states.
  • One participant notes that the charge of iodine is typically negative one, which influences the naming of the compound.
  • Several participants discuss the existence of other compounds of oxygen and iodine with different ratios, listing examples such as I2O4, I2O5, and I2O7, but express uncertainty about their prevalence in literature.
  • There is a discussion about the general rule for naming compounds based on the position of elements in the periodic table, with some participants agreeing that it is not always applicable, especially for compounds involving oxygen and halogens.
  • One participant mentions that simplified sources may claim Nickel has only one charge, while more comprehensive chemistry texts indicate the presence of multiple oxidation states.
Participants express differing views on the naming of OI2 and the oxidation states of Nickel, indicating that multiple competing perspectives remain unresolved.
Some participants reference various textbooks and resources, noting discrepancies in the information provided, which may affect the understanding of oxidation states and compound naming conventions.
This discussion may be useful for students learning about chemical nomenclature, oxidation states of transition metals, and the properties of covalent compounds.
DarylMBCP
What is the chemical name for OI2? Does Nickel have more than one charge like most other transition metals?
I think the name for OI2 is Oxygen diiodide. This sounds really weird. How about other instances if there are I3,I4,I5 or even I6 in a covalent compound?
One of my bks says it does while another says it does't.
Oxygen diiodide sound soK to me, but English nomenclature is not my forte.
Ni(II) is the most stable, other oxidation states were definitely observed but are rare.
The oxidation state of Oxygen can easily be inferred knowing that the charge of the I will be negative one. Best guess is that compound you show is called oxygen iodide.
For other reduction states of Nickel maybe try looking in a table of electromotive series (reduction tables). Do you find any Nickel ions other than Nickel(II) ?
Borek, do you if there are other compounds of only Oxygen and Iodine which have different ratios?
On the second thought - I would rather go for diiodine oxide. Oxygen is more electronegative.
Note, that the effect may depend on the tables used. Some of my books list only Ni2+. Do not mistake absence of evidence for the evidence of absence :smile:
Several. I2O4, I2O5, I2O7, I4O9 (first two are listed in several books, last two - each in one book only, no idea what it means). Interestingly, none of those books lists I2O.
Note: apart from translated Sienko/Plane, all other books I have consulted were published only in Polish.
Thank you but I've not learned about oxidation states yet. However, I've read before that in a compound, the element that is more to the left in the periodic table or, if both are in the same group, then the one that is higher is written first. Is my resource right? As for nickel, the conclusion being made is that Nickel is similar to Zinc, in having only one possible charge. Am I right?
Only approximately. To some extent that's the way electronegativity of elemnets changes in the periodic table. It will work in most cases, but not for compounds of oxygen and halogens.
From Principles of Chemical Nomenclature, A GUIDE TO IUPAC RECOMMENDATIONS, section 4.2 BINARY-TYPE NOMENCLATURE, subsection 4.2.2 Name derivation (page 28):
The electropositive constituent names are cited first, and are separated from the electronegative constituent names by a space
So there is oxygen fluoride, but chlorine, bromium and iodine oxides.
Again, it depends where you check. Simplified sources claim that Ni forms only Ni2+ cations, real chemistry books list several other cations. There are not many compounds where nickel has valence other than II, but there is no doubt they exist.
Ok, thank you for your replies.
  • · Replies 46 ·
