What Is the Speed of a Bowling Ball When It Rolls Without Sliding?
The discussion revolves around the transition of a bowling ball from sliding to rolling motion, specifically analyzing its speed when it rolls without sliding. The subject area includes concepts of angular momentum, friction, and the dynamics of motion.
  • The original poster attempts to understand the conceptual shift from kinetic to static friction and the role of angular momentum in this transition. Some participants suggest calculating angular momentum with respect to the contact point and equating initial and final states to find the final linear velocity.
Participants are exploring various aspects of the problem, including the implications of angular momentum and the effects of friction. Some guidance has been offered regarding the conservation of angular momentum, but there is no explicit consensus on the approach to take.
There is a noted uncertainty regarding the conditions that lead to the bowling ball starting to roll, and the discussion touches on the distinction between statics and kinematics in this context.
thejinx0r
[solved] Angular Momentum - Bowling ball
A bowling ball is thrown down the alley with speed [tex]v_0[/tex]. Initially, it slides without rolling, but due to friction, it begins to roll. Show that it's speed when it rolls without sliding is [tex]5/7 v_0[/tex]
[tex]\tau = \vec R \times \vec f[/tex] where f is the force friction.
[tex]\vec L = \vec R \times M\vec V[/tex]
[tex]\vec v_f = \vec a t +\vec v_0[/tex]
I don't understand what is really going on conceptually when it goes from sliding to rolling.
I know that when it slides, it's kinetic friction, and when it slides, it's static friction.
So, there must be something that makes the bowling ball go from kinetic to static friction.
What that is, is where I go lost.
So I drew my FBD's. I set the origin along the axis of friction.
As it slides, there's gravity, the normal and kinetic friction in the usual places.
As it rolls, it's the same as above, but with static friction force and an arrow showing angular momentum.
Initially, it had no angular momentum because [tex]\vec L_0 = I_o \omega[/tex] , but [tex]\omega = 0[/tex] initally ([tex]\omega[/tex]is angular velocity)
Thus, angular momentum would just be [tex]\vec L = \vec R \times M\vec V[/tex].
I know there's torque being applied due to friction which would be equal to rf*sin(theta).
Thereafter, I just wrote a bunch of equations down and I tried to see what would happen if I tried to solve for the force of friction using torque, but that leads no where. I tried going through linear energy and linear momentum, but that leads no where since I don't know under what condition it would make the bowling ball start rolling.
The trick is to recognize that the ball's angular momentum, calculated with respect to the (moving) contact point remains CONSTANT throughout the motion.
The reason for that is three-fold:
1. The velocity of the the moving contact point is always parallell to the velocity of the ball's centre, under the fair assumption that that is, indeed, the centre of mass of the ball.
2. The friction acts AT the contact point, and hence, would not contribute to the angular momentum as calculated with respect to the contact point.
3. Gravity, which can be considered acting at the centre of mass, acts in a parallell direction to the distance vector between the contact point and the mass centre, and hence, it generates 0 torque about the contact point.
In order to solve the problem:
1. Calculate initial angular momentum wrt. to the contact point.
2. Calculate final angular momentum wrt. to the contact point.
3. Set these results equal to another, and solve for final linear velocity in terms of v0
Thank you so much.
I honestly did think about that case.
But something made me think that it meant that it wasn't moving.
thejinx0r said:
Thank you so much.
In general, conservation of POSITION is dealt with within the statics sub-branch of mechanics, rather than within kinematics.
:smile:
