Designing a parachute system/device
The discussion revolves around designing a parachute activation system that triggers a servo when a signal is lost between a machine and a remote control. Participants explore various approaches to linking components, including the use of sensors and dead man switches, within the context of mechanical and electrical engineering.
  • One participant seeks assistance in building a system that activates a servo upon loss of signal between a machine and remote, questioning the feasibility of using a sensor to monitor the signal.
  • Another participant suggests using a 'dead man switch' that could maintain a relay in an open state during signal presence, which would close and trigger the parachute system upon signal loss.
  • There is a discussion about whether the dead man switch requires multiple connections and what specific hardware would be necessary to implement this solution.
  • A clarification is provided on the concept of a dead man switch, explaining it as a device that requires continuous effort to prevent an action from occurring.
Participants express interest in the dead man switch concept, but there remains uncertainty about the specific hardware requirements and whether additional components are necessary. The discussion does not reach a consensus on the best approach.
Participants have not fully resolved the technical details regarding the integration of components or the exact implementation of the dead man switch in this context.
Panic Attack
I am trying to build a system to activate a servo at a unspecified point in time when a machine and remote looses their signal between another. When the signal is lost between the two, the new system must activate a servo. We are using radio transmitters, but I can't figure out how to tackle this problem. Any assistance would be LOVED!
The biggest problem I am having is how to link these three things together. I was thinking about using a sensor that monitors the 2-way signal between machine and remote with a LED, then the LED turns on or maybe stops the LED when the signal is lost, then activates the actuator... i don't know...
can i build a sensor that does this?
Should I buy transmiter and put it on the plane and connect the reciever to a circuit that activates the servo? I am trying to make this happen without me doing it manually. Does this make any sense? This project uses mechanical and electrical engineering components and I design it
I would think that a 'dead man switch' would be appropriate. Can you just dedicate one channel to a continuous broadcast that orders a relay to remain open? When the signal is lost, the relay should energize and trigger your 'chute system.
edit: I guess that I mean 'de-energize'. I was thinking of the secondary rather than primary circuit.
edit #2: I just noticed that you also have this posted in 'Mechanical Engineering', and Topher gave you a great response.
THis will be another component I will do intensive research. A "dead-man switch" sounds like what I am looking for. I think we have an extra channel that sends a relay. I am curious, does the "dead man's switch" do all of this or do I need multiple connections and receivers/transmitters... lol basically, what hardware do I need to bring this to life...
I FORGOT TO THANK YOU! BECAUSE THIS HELP IS SINCERELY APPRECIATED
A dead man switch simply means any type of device that requires some sort of effort (be it mechanical or electric or other) to STOP an action (such as closing a circuit) from occurring. If the (mechanical or electric or other) effort ceases, the switch closes.
  • · Replies 17 ·
