Work Done without using the Conservation of Energy
The problem involves calculating the work done in moving a small mass over a frictionless half cylinder using a massless cord, without employing the conservation of energy principle. The context includes concepts from mechanics, specifically relating to forces and work done against gravitational pull.
  • Participants discuss setting up an integral to calculate work done, with emphasis on determining the force applied as a function of position along the cylinder. There are questions about the role of tension and the effect of gravitational force at different angles.
Participants are actively exploring the setup of the integral and the forces involved. Some have suggested focusing solely on the tension force, while others are clarifying how to express the tension as a function of angle. There is acknowledgment of the need to check results against conservation of energy, although some express uncertainty about how to do this without knowing the speed.
Participants note the challenge of disregarding the normal force and the varying effects of gravitational force at different positions on the cylinder. The discussion reflects a mix of understanding and confusion regarding the setup of the problem and the forces at play.
veronicak5678
A small mass m is pulled over the top of a frictionless half cylinder of radius R by a massless cord passing over the top. Without using the conservation of energy, find the work done in moving the mass from the bottom to the top of the cylinder at a constant speed, in terms of m, g, and R.
Really not sure how to approach this... Can I somehow set up an integral?
Yes, you'll need to set up an integral of F*ds along the cylinder. Figure out the force that must be applied as a function of position along the cylinder. Hint: Measure position in terms of angle, from 0 to ∏/2 radians.
I understand the concept, but I am still having trouble setting up the function. I guess I can disregard normal force, so the only force doing work is the tension.
So the work of tension is Force of T * displacement * cos angle. Since the tension is always in the same direction as the displacement, the angle will always be cos 0, or 1, so I can leave that out. The displacement will be R * angle. I don't know how to figure out the force of the tension at any given point since the weight is sometimes pulling down (like at 0 degrees) and sometimes at a right angle, where I think it should then be doing no work.
Yes. We only care about the work done by the tension force.
At any given position, the infinitesimal displacement will be Rdθ.
Since the speed is constant, the tension must be just enough to balance out the tangential component of the weight. Find that as a function of θ.
Not sure I know how to do that...
I think the integral should be from 0 to pi/ 2 of Rdtheta * wcos theta?
Exactly!
Now just do that integral.
Also: check your answer. you should be able to use conservation of energy to check it at least!
I did a similar problem (frictionless half-pipe) with some AP teachers in outreach last month.
So the work done is just wR [sin theta]0 to pi/2 =
wR sin(pi/2) - wR sin(0) = wR ?
Also, how can I check using the conservation of energy if I don't know the speed?
Yep.
The speed doesn't change.
OK. I get it. Thanks to all of you for your help!
  • · Replies 58 ·
  • · Replies 28 ·
