Acceleration from Time & Distance.
  • Thread starter Thread starter JanineSamson
    Acceleration Time
The discussion revolves around calculating acceleration from given distance and time values in a physics context. The original poster presents a scenario involving an object starting from rest, with specific distance and time measurements, and seeks clarification on the methods for determining acceleration.
  • The original poster attempts to use two different methods to calculate acceleration, leading to different results. Some participants question the validity of the methods and the assumptions made regarding motion. Others suggest that the discrepancy arises from using average velocity in one of the calculations.
Participants are exploring the implications of the original poster's calculations and discussing the conditions under which each method is valid. There is acknowledgment of the need for uniform acceleration in the context of the problem, and some guidance has been offered regarding the interpretation of average velocity versus instantaneous acceleration.
There is an underlying assumption of uniformly accelerated motion, which is being discussed among participants. The original poster's lack of formal physics education is noted, and this may influence the clarity of the problem setup.
JanineSamson
Hi Everyone,
I haven't had any Physics education so I'll apologise in advance because this question is probably going to be stupid.
If I had something starting from rest (u = 0) and I have a distance (s = 0.8m), and time it takes to travel that distance (t = 1.9s), which way would you go about working out the acceleration?
I can see two ways, but one of them is obviously incorrect because you end up with different answers.
1.
Use
[tex]s = ut + 1/2at^2[/tex]
Since u = 0
[tex]s = 1/2at^2[/tex]
rearranging...
[tex]a = 2s/t^2[/tex]
Which with my numbers would give, a = 1.6/3.61 = 0.443ms^-22.
Find the velocity using s/t, so v = 0.8/1.9 = 0.42ms^-1
then a = (v - u) / t = (0.42 - 0) / 1.9 = 0.221ms^-2
Is one of those methods correct? I thought they would both come out the same... but they don't so I seem to be doing something horribly wrong.
Any help would be greatly appreciated, many thanks,
Janine.
Your statement of the problem allows many accelerations to be correct.
1. Your first answer is correct for constant acceleration beginning at t=0.
2. If your second answer for the velocity v is correct, then your answer for the acceleration is wrong. In this case, the velocity jumps from 0 to v at t=0, ie. infinite acceleration at t=0. After that, the velocity is constant and there is zero acceleration for the rest of the trip.
That was, in fact, the problem that lead to the development of the calculus. If you were in a spaceship far above the plane of the solar system, you could take a photograph, measure the distance from the sun to the planet and, if gravity were just a function of distance, calculate the force and so acceleration. But acceleration, as defined then, could not be calculated at a given instant as could the distance between the sun and the planet.
So: to calculate acceleration either 1) get the position as a function of time and differentiate twice or 2) get the position at 3 different times so you can calculate two different (average) speeds and from that an average acceleration.
If you can assume uniformly accelerated rectilinear motion, your first method is correct and the only problem with your second method is that you are using the average velocity to calculate the acceleration. The average velocity of 0.42 m/s, that you calculated is midway between the start, 0 and the final velocity at 1.9 seconds. So the final velocity is 0.84 m/s. If you use that number to calculate the average acceleration you get 0.84 / 1.9 = .442 m/s^2 which agrees with your first method. Again, all of this is assuming uniformly accelerated straight line motion.
Thanks for the replies everyone! That's a great help.
