Why Do Particles c and d Vibrate in Phase with Particle b in a Wave?
  • Thread starter Thread starter Johnny Leong
    Physics Wave
Particles c and d vibrate in phase with particle b in a wave, as they are all positioned at crests with the same amplitude and wavelength. This means they move in unison, confirming their phase alignment. The spongy lining at the edges of a ripple tank absorbs waves to prevent reflections, allowing for clearer observation of wave behavior. This setup is crucial for accurate physics experiments involving wave dynamics.
  • Understanding of wave mechanics, specifically amplitude and wavelength.
  • Familiarity with the concept of phase in wave motion.
  • Knowledge of ripple tank experiments in physics.
  • Basic principles of wave reflection and absorption.
  • Study the principles of wave interference and superposition.
  • Explore the effects of boundary conditions on wave behavior in ripple tanks.
  • Learn about different types of waves, including longitudinal and transverse waves.
  • Investigate the role of damping in wave motion and its applications.
Students and educators in physics, particularly those focusing on wave mechanics, as well as researchers conducting experiments with ripple tanks and wave behavior analysis.
Johnny Leong
From the figure, please see the attachment. Which particles vibrate in phase with particle b and why?
Can I say that particle c and d vibrate in phase with particle b?
Another question: What is the function of the spongy lining at the edges of ripple tank when we generate water wave in the ripple tank?
Assuming that you mean you picture to represent a wave with the two endpoints fixed, then d is in phase with b (they will always be at the same height). c is not.
As for the spongy lining, it is there to absorb the wave so you won't have reflections confusing the situation.
In a wave problem in physics, it is important to understand the concept of phase and how particles vibrate in relation to each other. In the given figure, particle b is shown to be at its highest displacement, or crest, while particles c and d are also at their respective crests. This means that they are all vibrating in phase with each other, meaning they are all moving in the same direction and at the same time. This is because they are all located at points on the wave with the same amplitude and wavelength, causing them to vibrate in unison.
To answer the question, yes, it is correct to say that particles c and d vibrate in phase with particle b. This can also be observed by looking at the wave pattern in the figure, where the crests of particles b, c, and d are all aligned.
Moving on to the second question, the spongy lining at the edges of a ripple tank serves as a boundary for the water waves that are generated. This helps to contain the waves within the tank and prevent them from reflecting off the edges. This allows for a more controlled and accurate observation of the wave behavior, as the waves will not be affected by any external factors. Additionally, the spongy lining also helps to reduce any interference from external vibrations, ensuring that the waves being observed are solely generated by the device in the tank.
  • · Replies 23 ·
