Thread Closed
How to solve Chips in milling machine?
Share Thread
Oct11-08, 10:18 PM   #1
1)Anyone can figure out the chips problem due to milling a glass material BK7.?
2) I am using Ichikawa Milling machine where the table rotate and the spindle rotate to mill the material. After do ralf cutting which I set the speed to 60. It produces chips on the edges of the piece.
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Oct11-08, 10:24 PM   #2
Recognitions:
Gold Membership Gold Member
Welcome to PF, Wise. You might need to clarify your question. I've had limited experience with machine tools, and your terminology is meaningless to me.
I've never heard of 'ralf-cutting', and your number '60' could mean anything from rpm's to depth of cut in thousandths. Please be more specific.
edit: As to the '60', I know that you said that the speed was set to '60', but that could still indicate a progressive depth vs. time as opposed to just rpm's.
Oct12-08, 04:35 PM   #3
Recognitions:
First thing I would try is to take a lighter cut at a higher speed with a slower feed rate.
Thread Closed
Tags
chips, milling machine
Similar Threads for: How to solve Chips in milling machine?
Thread Forum Replies
Analysis of Milling Fixture Mechanical Engineering 0
chips and dip Introductory Physics Homework 2
Transporting machine(actually cloning machine) General Discussion 15
chips Medical Sciences 6
How do CPU chips work Computing & Technology 7
