Acceleration of a ball thrown upwards.
  • Thread starter Thread starter kbncp
    Acceleration Ball
The problem involves analyzing the acceleration of a ball thrown upwards at different points in its trajectory, specifically just after leaving the hand, at the highest point, and just before hitting the ground. The context is kinematics, focusing on the effects of gravity on the ball's motion.
  • Participants discuss the nature of acceleration at various points in the ball's flight, with some attempting to justify their answers based on the ball's motion and the effects of gravity. Questions arise regarding the distinction between speed and velocity, and the implications of neglecting air friction.
The discussion is ongoing, with some participants questioning the correctness of the original poster's answers and encouraging deeper reasoning. There is a mix of interpretations regarding the relationship between velocity and acceleration, and the role of air resistance is also mentioned.
There is an assumption that air friction is neglected, which may affect the accuracy of the answers provided. The original poster's responses are noted as potentially incorrect, prompting further exploration of the concepts involved.
kbncp
A ball is thrown up the top of the tower. At each of the following instants is the ball's acceleration larger than g, equal to g, or -g (assume up is positive, g=9.8m/s2)
a) Just after leaving your hand?
b) When the ball is at its highest point?
c) Just before hitting the ground?
a) -g
b) -g
c) g
Your answers are not all correct: but you should say more about how you arrived at your answers. If they are random guesses then you should try harder.
In any case, I suppose air friction is neglected here, otherwise the correct answer is not always among the 3 choices!
well the first two answers.. since the ball is moving up.. it is eventually going to reach a velocity of 0, so it slows down.. so acceleration is -g... And when it is moving down... the velocity gets faster and faster.. so i would assume that the acceleration would be g
Maybe you're confusing speed and velocity: it's not just about "speeding up" or "slowing down," [which refer to speed, really] it's the direction of the change in velocity which is important.
  • · Replies 38 ·
14K
