Building 10 Synchronized 7-Segment Clocks
  • Thread starter Thread starter Liad
    Clocks
The discussion revolves around the construction of 10 synchronized 7-segment clocks, focusing on synchronization methods, power sources, and technical considerations for implementation.
  • One participant suggests building microprocessor-based clocks that can synchronize with each other.
  • Another participant proposes using 10 radio-controlled clocks as a potential solution.
  • A question is raised regarding the power source for the clocks, with a suggestion that if they can count AC Mains 60Hz zero-crossings, they could remain synchronized automatically.
  • Discussion includes a mention of methods to synchronize clocks with extremely high precision, questioning the actual precision requirements for the project.
  • A link is provided to a resource that discusses using an AT90S2313 chip for driving multiple displays, suggesting the need for additional transistor stages to support 10 displays and a specific wiring configuration.
Participants present multiple competing views on synchronization methods and power sources, and the discussion remains unresolved regarding the best approach to achieve synchronization.
Participants express uncertainty about the precision requirements and the specific implementation details, such as power sources and wiring configurations.
Liad
Hey!
I need to build 10 7segment clocks that will be synchronized among themselves.
[Just a regular clock that will display the current hour, only 10 of those, and in different places in the room].
I thought about building a microProcessor-based clocks that will be synchronized among themselves.
How do I do it in that way or any other way?
Any suggestions will be great!
Liad.
10 radio controlled clocks.
How are they powered? If they can count AC Mains 60Hz zero-crossings, they will stay synchronized automatically.
And how precise does it have to be? There are now methods that can be used to synchronize two clocks with a precision better than 1 part in 10^18 over a distance of a few km.
Now, I am guessing that you don't need that kind of precision:wink: but the point is that there are standardized methods for synchronizing clocks with very high precision; so the question is what you need?
http://www.h-renrew.de/h/avrclock/avrclock.html
Repeat the display part 10 times but you may need extra transistor stages to allow the clock chip to drive 10 displays.. Always will be locked and only one setting operation. Link by a ring - 17 way mini cable. Chip is AT90S2313
Maxim make clock and display chips.
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 44 ·
  • · Replies 17 ·
