Another Driven Harmonic Oscillator problem
The discussion revolves around a driven harmonic oscillator described by a differential equation. Participants are tasked with verifying a given solution that satisfies specific initial conditions.
  • Participants discuss the verification of the provided solution against the boundary conditions. Some express uncertainty about whether they need to derive complementary solutions or focus solely on the given solution.
There is an ongoing exploration of how to approach the problem, with some participants suggesting that verification of the given solution is sufficient. Others question the necessity of finding additional solutions, indicating a mix of interpretations regarding the requirements of the task.
Some participants mention the need to check boundary conditions, while others emphasize that the task is not to solve the equation but to verify the provided solution. There is a mention of initial conditions and the implications of the problem setup.
Benzoate
A driven oscillator satisfies the equation
x'' + omega2=F0cos(omega(1+episilon)t]
where episilon is a positive constant. Show that the solution that satisfies the iniitial conditions x=0 and x'=0 when t=0 is
x= (F0*sin(.5episilon*omega * t) sin(omega(1+.5episilon)t)/(episilon(1+.5episilon)omega^2)
cos(omega*t)=cos omega(1+.5episilon)t-.5omega*t)
cos(omega(1+episilon)t)=cos(omega(1+.5episilon)t + .5omega*t)
let x=ceiwpt
x'= ciwpeiwpt
x''= -c*wpe]iwpt
c= F0/(-wp2+omega^2)
Therefore
x= (F0/(-wp2+omega^2))*ceiwpt
Am I heading in the right direction
Should I derived an equation for the complimentary solution?
let x=ceiwpt
x'= ciwpeiwpt
x''= -c*wpe]iwpt
Therefore
You are given a solutions, and all you are asked to do it verify that what you are given is indeed a solution. You are not asked to solve the equation for x(t) you are only asked to check that the given solution is correct.
So... take what you are given and first check that it satisfies the boundary conditions. For very first, check that it satisfies x(0)=0. Can you verify this?
my equation for my driven response looks like:
xp=(F0*eiwp*t
For complementary/transient motion should my equation be:
xc=A*cos(wp*t)+B*sin(wp*t)=0
Have you even read the previous post? You are not required to solve any equations, you need to simply check that the given solution satisfies the boundary value problem.
But don't I need to find the equation for the driven response and the equation for the transient motion?
general solution
x=xc+xp= A*cos(wp*t)+B*sin(wp*t)+(F0*eiwp*t)/(w0^2-w^2)^2 and now that I have a general solution I can plug in my initial conditions that will helped me find A and B and I now that I have A and B, I can convert my general solution to the particular solution in the book?
general solution
No, you don't need to find the general solution, you are given the particular solution! Of course you could go through all the trouble of solving the differential equation, then imposing the boundary conditions and finally showing that your solution is equivalent to that given. However, a much more straight forward method would be to simply substitute the given solution into the differential equation and check that the equation (and all boundary conditions) are satisfied.
Do you follow?
Do you follow?
yes. Thanks.
  • · Replies 16 ·
  • · Replies 19 ·
