How to Prove the Sum of Squared Standard Normal Variables is Chi-Square?
The sum of squared standard normal variables Z1, Z2,..., Zn, which are identically and independently distributed, results in a Chi-square random variable with n degrees of freedom. This can be proven by establishing the cumulative distribution function F(a) = Pr(X^2 ≤ a) and deriving its density function f(a) = F'(a) for a central chi-square distribution with 1 degree of freedom. Additionally, the moment-generating function method demonstrates that the sum of n independent chi-square variables also follows a chi-square distribution with n degrees of freedom. Induction can be applied to show that the sum of two independent chi-square variables W and Y, with n1 and n2 degrees of freedom respectively, results in a chi-square variable with n1 + n2 degrees of freedom.
  • Understanding of standard normal random variables
  • Familiarity with cumulative distribution functions (CDF)
  • Knowledge of moment-generating functions
  • Basic principles of mathematical induction
  • Study the properties of Chi-square distributions and their applications
  • Learn about moment-generating functions and their role in probability theory
  • Explore the concept of mathematical induction in proofs
  • Investigate the relationship between independent random variables and their distributions
Statisticians, data scientists, and students of probability theory who are looking to deepen their understanding of Chi-square distributions and their derivations.
stattheory
If Z1,Z2...Zn are standard normal random variable that are identically and independently distrubuted, then how can one prove that squaring and summing them will produce a Chi-
squared random variable with n degrees of freedom.
Any help on this will be greatly appreciated. I am new to this stuff and often get confused in it.
Stattheory.
Several ways. Start with one, set up
[tex] F(a) = \Pr(X^2 \le a) = \Pr(-\sqrt{a} \le X \le \sqrt{a})[/tex]
and show that [tex]f(a) = F'(a)[/tex] is the density for a central chi-square with 1 degree of freedom.
Then use the moment=generating method to show that the sum of [tex]n[/tex] chi-squares has a chi-square distribution with [tex]n[/tex] degrees of freedom.
Or, if you haven't seen moment-generating functions, start as above for 1, then
show that if [tex]W, Y[/tex] are two independent chi-square random variables, with [tex]n_1[/tex] and [tex]n_2[/tex] degrees of freedom, the sum [tex]W + Y[/tex] is chi-square with [tex]n_1 + n_2[/tex] degrees of freedom. The use induction for your case.
There are other ways, and I'm sure they will get proposed.
  • · Replies 39 ·
