Fredholm equation of the second kind
  • Thread starter Thread starter danbone87
The discussion revolves around proving the functional linearity of a Fredholm equation of the second kind, specifically in the context of the equation y(x) = x + ∫[0,1](x²t)y(t)dt. The original poster expresses confusion regarding the concept of functional linearity and its relation to their problem, as well as the need for an analytical solution involving a low order polynomial.
  • Participants discuss the definition of functional linearity and its implications for the operator involved. The original poster considers using integration by parts and setting up a differential equation. Another participant suggests simplifying the equation by introducing a constant A derived from the integral, leading to a polynomial form. The original poster later questions the need for a specific proof format involving linear combinations of functions.
The discussion is active, with participants providing clarifications and suggestions for approaching the problem. There is acknowledgment of helpful insights, but no consensus on the final approach or proof structure has been reached.
The original poster mentions a lack of resources in their numerical analysis book and expresses uncertainty about the requirements for the proof format, indicating potential constraints in their understanding and available materials.
danbone87
I need to prove that a Fredholm equation of the second kind is functionally linear.
I'm not sure what functional linearity is or if that's exactly what is being asked because it's not in my numerical analysis book and everytime i look on the internet I'm referred to linear algebra.
Can someone get me on the right track as far as what I'm actually looking to prove?edit: I also need to solve a fredholm eqn of the second kind analytically. Hint: my result should contain a low order polynomial.
it is y(x) = x + integral[0,1](x^2*t)y(t)dt
every example i see is numerical integration. so i couldn't find any examples to work off of.
should i do integration by parts on the integrand and then set up a differential equation involving Y(t) and y(x) and then solve with a characteristic polynomial?
Saying that an operator, U(f), is "functionally linear" means that U(af+ bg)= aU(f)+ bU(g) where f and g are functions and a and b are numbers.
The equation you are asked to solve is [itex]y(x)= x+ \int_0^1 x^2ty(t)dt= x+ x^2\int_0^1 ty(t)dt[/itex].
If you let [itex]A= \int_0^1 ty(t)dt[/itex], a number, then your equation is simply y(x)= x+ Ax2. that's the "low order polynomial" you mention. You only need to determine what A is. Multiply on both sides by x to get xy(x)= x2+ Ax3 and integrate from 0 to 1. The left side is just X so you get a linear equation to solve for x.
thanks so much that helps everything.
uh, apparently i need the proof in the form of c1y1+c2y2 = f and Lf=y. in this case do i need to use method of undetermined coeffecients with the y(x)=x+ax^2 ?
bump. Any help is greatly appreciated!
The Rock says...
