Velocity Time Graphs and Questions
This discussion centers on a physics problem involving two balls thrown from a balcony 19.6 meters high, one downward at 14.7 m/s and the other upward at the same speed. The time spent in the air for both balls is calculated to be 3.0 seconds. Both balls strike the ground with the same velocity of 14.7 m/s, as the upward-thrown ball returns to the same height from which it was thrown. To determine their positions 0.800 seconds after being thrown, kinematic equations must be applied to calculate their respective distances from the balcony.
  • Understanding of kinematic equations in physics
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Familiarity with initial and final velocity concepts
  • Ability to perform calculations involving displacement and time
  • Study kinematic equations for vertical motion in physics
  • Learn how to calculate displacement using the equation x = Xi + Vi*t + 1/2*g*t²
  • Explore the concept of velocity in projectile motion
  • Practice problems involving objects thrown vertically with varying initial velocities
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and its calculations.
Run4Fun
I've been working on this one problem for a while and I don't really seem to understand it. If you could help me understand how to do this, I would be much obliged.
Two students are on a balcony 19.6 m about the street. One student throws a ball vertically downward at 14.7 m/s. At the same instant, the other student throws a ball vertically upward at the same speed. The socond ball just misses the balcony on the way down.
a. What is the difference in the time the balls spend in the air?
b. What is the velocity of each ball as it strikes the ground?
c. How far apart ar the balls 0.800 s after they are thrown?
I attempted the first one and got it right (by a miracle in my opinion)- 3.0 Seconds
But I seem to be stuck when it comes to b.
The velocities of each ball right before they hit the ground will be equal (since when the ball thrown vertically upward comes back down to the point from which it was thrown, it's velocity will be the negative of it's initial velocity, 14.7 m/s. And that is the same velocity the first ball was thrown straight down with)
You can use kinematic equations to solve for final velocity (displacement = -19.6m, acceleration = -9.8m/s/s, Vi= +/- 14.7 m/s, then solve for Vf)
c. How far apart ar the balls 0.800 s after they are thrown?I attempted the first one and got it right (by a miracle in my opinion)- 3.0 Seconds
Welcome to PF.
It shouldn't take a miracle to figure the first one.
Whatever the speed thrown upward will be the same speed as it passes the same height on the way down. That simply makes it a calculation of how long to go up from the balcony and back down.
14.7m/s/9.8m/s2 = 1.5 is how long to go up and double it for the up and down. 3 seconds.
For b) since they both pass the balcony at the same speed they will strike the ground with the same speed.
V2 = Vi2 + 2*g*x
For c) you need to use x = Xi + Vi*t +1/2*g*t2 (appropriately set up for each ball) and calculate the positions of each at .8s.
