Radial and tangential acceleration
The discussion focuses on calculating radial and tangential acceleration for a point on a rotating turntable, specifically at a distance of 21.5 cm from the center. The point accelerates from rest to a speed of 0.800 m/s over 1.75 seconds. Key equations used include radial acceleration (a_r = -v^2/r) and tangential acceleration (a_t = d|v|/dt). Participants seek clarification on the calculations and values used to determine the magnitudes and directions of these accelerations at t = 1.28 seconds.
  • Understanding of circular motion concepts
  • Familiarity with acceleration equations
  • Knowledge of angular velocity and its relationship to linear velocity
  • Basic algebra for solving equations
  • Calculate radial acceleration using a_r = -v^2/r for various speeds
  • Explore tangential acceleration calculations with different time intervals
  • Study the relationship between angular velocity and linear velocity
  • Investigate total acceleration in circular motion scenarios
Students studying physics, particularly those focusing on rotational dynamics, as well as educators seeking to clarify concepts of radial and tangential acceleration.
steph35
A point on a rotating turntable 21.5 cm from the center accelerates from rest to a final speed of 0.800 m/s in 1.75 s. At t = 1.28 s, find the magnitude and direction of each of the following.
(a) the radial acceleration
(b) the tangential acceleration
(c) the total acceleration of the point
? m/s^2, ? °
for this i used the right equations for the give times and substituded V= 2pir/T but i didnt get the right answer. i used a_r= -v^2/r and a_t= d|v|/dt...can somebody explain it in a simple way...
Hi steph35,
? m/s^2, ? °
What numbers did you use, and what answers did you get for the three accelerations?
11K
