Magnetic flux through loop inside of solenoid
The problem involves calculating the magnetic flux through a circular wire loop located inside a solenoid and determining the average induced emf when the current in the solenoid is switched off. The context includes parameters such as the solenoid's dimensions, number of turns, and current values.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of magnetic flux using the formula for the magnetic field inside a solenoid and the area of the loop. Questions arise regarding the correct interpretation of the number of turns per unit length and the application of relevant equations for induced emf.
Some participants have provided guidance on the correct approach to calculating magnetic flux and induced emf. There is recognition of different methods to arrive at the average emf, and participants are exploring the implications of their calculations and assumptions.
Participants note confusion regarding the application of formulas and the importance of using the correct parameters, such as the radius instead of the diameter. There is also discussion about the assumptions made in the problem regarding the transition of current and its effect on induced emf.
as11
A solenoid has 1800 turns of wire and is 125 cm long and 10.0 cm in diameter; see Figure P.14 (attached). A circular wire loop of diameter 5.0 cm lies along the axis of the solenoid near the middle of its length as shown.
(a) If the current in the solenoid initially is 4.0 A, find the magnetic flux through the smaller loop.
(b) If the current in the solenoid is switched off and falls to zero in 3.0 s, calculate the average value of the emf induced in the smaller loop.
1. B(inside solenoid) = [tex]\mu[/tex]0*n*I, where n=number turns, I= current
2. [tex]\Phi[/tex]magnetic=[tex]\int[/tex][tex]\stackrel{\rightarrow}{B}[/tex]*[tex]\stackrel{\rightarrow}{dA}[/tex]
[tex]\Phi[/tex]magnetic=[tex]\int[/tex][tex]\stackrel{\rightarrow}{B}[/tex]*[tex]\stackrel{\rightarrow}{dA}[/tex] = BA = B*[tex]\pi[/tex]*r2 (this did not work, and as I did not get the first part, I had no idea how to even approach the second part...thanks for any advice).
Why do you say it "didn't work"? Show exactly what you did.
My apologies.
So B(inside solenoid) = [tex]\mu[/tex]0*n*I = (1.2566 x 10-6)*(1800)*(4.0A) = .009048 T
Area loop = [tex]\pi[/tex]*r2 = [tex]\pi[/tex]* (6.25 x 10-4) = .0019635 m2
so, if [tex]\Phi[/tex]= BA = (.009048 T) * (.0019635 m2) = 1.7766 x 10-5
but this answer was marked incorrect.
In the equation B = μ*n*I, n is the number of turns per unit length, not just the number of turns.
So to find the flux through the smaller loop do you first find the flux through the solenoid using its area and then somehow use the smaller loop's area to find its flux?
You find the field within the solenoid (which is given by B = μ*n*I), then use it to calculate the flux through the smaller loop's area.
Thanks that worked; I tried that before, but used the diameter instead radius. woops
Part B is giving me trouble as well.
induced emf = -NA * dB/dt
=-1800*(.025)^2 * pi * (-4/3)
Wrong equation, never mind.
induced emf = -L * dI/dt
L= flux / I
I don't think you have to use an equation; it's asking for the average emf and
emf = -dflux /dt
and dflux= flux2 - flux1 , but flux2 = 0 because the current goes to 0 (stated in problem)
and dt is given in the problem
Your right; you can get the same solution both ways,
  • · Replies 31 ·
