Heat transfer equation within soils
  • Context: Undergrad
  • Thread starter Thread starter riscy
    Heat Heat transfer
The discussion focuses on estimating heat transfer in soils using a simple equation for conduction, specifically between a 2-meter-long metal rod with a built-in 10KW heater and various soil types. The goal is to calculate the temperature at both the rod and a temperature probe placed 2 meters away, while assuming negligible convection and radiation effects. Key references include data from Oklahoma State University and ASHRAE Handbooks, emphasizing the importance of soil moisture content in heat extraction for Ground Source Heat Pump systems.
  • Understanding of heat transfer principles, specifically conduction.
  • Familiarity with Ground Source Heat Pump systems.
  • Knowledge of soil thermal properties, including conductivity and thermal diffusion.
  • Basic mathematical skills for applying heat transfer equations.
  • Research the heat conduction properties of various soil types.
  • Study the ASHRAE Handbooks for guidelines on thermal performance in soils.
  • Explore the heat extraction methods used in Ground Source Heat Pump systems.
  • Investigate the impact of soil moisture content on thermal conductivity.
Engineers, researchers, and professionals involved in geothermal energy systems, particularly those focused on heat transfer in soils and Ground Source Heat Pump applications.
riscy
I'm seek simple equation that estimate the heat transfer (W/K.m2), conductivity and thermal diffusion rate between cylinder metal rod, about 2 meter length with build in heater of say 10KW and the soil of different type of conductivity and thermal diffusion stated in most textbook.
For example I insert a cylinder rod 10meter within the soil (relative to the surface) and place temperature probe 2 meter from the cylinder, I like a equation to estimate the temperature at the cylinder and the temperature probe and thus validate the actual measurement.
I'm only interested in conduction (ie convection and radiation could be assumed negligible).
The idea is to measure soil performance in removing heat as part of Ground Source Heat Pump pipe networks.
I prefer to avoid complex solution involving vector or such, since withdealing with simple problem, I willing to accept reasonable assumption about the solution.
Please submit comment/paper to riscy00@googlemail.com, no spam please.
Richard Payne
Science news on Phys.org
Why? surely there is data on different soil types for engineering applications.
search google for heat conduction of soil...IEEE has data...
There has been a lot of research done on heat extraction from soils by ground source heat pumps. I believe Oklahoma State University has a ground source heat pump research program (or did have). Moisture content of the soil is an important factor. ASHRAE Handbooks would probably be useful as well.
  • · Replies 28 ·
