Frequency of oscillating cylinder
The discussion centers on calculating the angular frequency (ω) of a rolling cylinder system when displaced from equilibrium, specifically under the condition that ρ_0 < ρ_1. The initial attempt yielded an incorrect formula for ω, calculated as ω = (ρ_1/(10ρ_0 + 6ρ_1))*(g/R). The correct formula is ω = (10(ρ_1 - ρ_0)/(7(ρ_1 + 31ρ_0))*(g/R), which aligns with the physical expectation that no oscillation occurs when ρ_1 equals ρ_0. Key equations involving linear forces and moments were discussed, highlighting the importance of accurate modeling in dynamic systems.
  • Understanding of angular frequency in oscillatory motion
  • Familiarity with rolling motion dynamics and friction
  • Knowledge of moment of inertia calculations
  • Proficiency in solving ordinary differential equations (ODEs)
  • Study the derivation of angular frequency in rolling systems
  • Learn about the effects of mass density on oscillatory motion
  • Explore the principles of friction in rolling motion without slipping
  • Investigate the application of ODEs in mechanical systems
Students and professionals in physics, mechanical engineering, and applied mathematics, particularly those focused on dynamics and oscillatory systems.
LiorE
The problem is this: Find the angular frequency of the system in the figure when it's displaced at a small angle from equlibrium, given that ρ_0 < ρ_1. There is friction with the ground, so the motion is a rolling motion, without slipping.
I used the following equations, and got a wrong answer:
f_s = friction
m = mass of small cylinder
M = mass of large cylinder
x = linear displacement from equilibrium
θ - angular displacement from equilibrium
for linear forces (here the tag stands for d/dt):
f_s = (m+M)x''
since it's a rolling motion:
x = Rθ
so: x'' = Rθ''
And the equation for the moments, from the center of the large cylinder (I think this is wrong):
f_sR - mgsinθ*R/2 = Iθ''
also:
m = (π ρ_1 R^2)/4
M = π ρ_0 R^2 - (π ρ_0 R^2)/4
I = π ρ_0 R^4 - (π ρ_0 R^4)/2 + (π ρ_1 R^4)/2
Using all the above equations and getting the ODE for x gives (unless I got the factors wrong):
This is not right - the right answer is:
Which is of course a lot more sensible since there shouldn't be an oscillation for ρ_1 = ρ_0, and for ρ_1 < ρ_0 the model is wrong.
So what's the right answer? And what am I doing wrong?
Thanks,
Lior
BTW - why isn't the latex working?
Oh, the figure...
4 characters
And also -
ρ_0, ρ_1 are the mass densities of the respective parts of the cylinder.
  • · Replies 21 ·
  • · Replies 97 ·
  • · Replies 24 ·
