Intergration to find work is from 0 to Y
  • Context: Undergrad
  • Thread starter Thread starter d_b
    Intergration Work
The discussion focuses on calculating the total work required to pump oil or water from a circular cylinder buried underground. When the cylinder is vertical, the integration for work is performed from 0 to Y, where Y represents the depth of the liquid. Conversely, for a horizontally positioned cylinder, the integration ranges from the top of the cylinder (its diameter) to the surface (diameter + X), where X is the depth of the cylinder. The participants also explore the scenario where the cylinder contains no liquid, questioning the relevance of work in that case.
  • Understanding of calculus, specifically integration techniques
  • Familiarity with concepts of work and energy in physics
  • Knowledge of fluid mechanics related to pumping systems
  • Basic geometry of circular cylinders
  • Study integration techniques in calculus, focusing on applications in physics
  • Research fluid dynamics principles, particularly related to pumping fluids
  • Learn about work-energy principles in physics
  • Explore practical applications of these concepts in engineering scenarios
Students and professionals in physics, engineering, and mathematics who are interested in fluid mechanics and work calculations related to pumping systems.
d_b
I have a question. If i have an object let say a circular cylinder buried underneath the Earth surface with X as its depth. I'm looking for the total work to plumb the oil or water that is in the cylinder to the surface
if the cylinder stand virtically and has water or oil in it(Y as its depth of water or oil) then the intergration to find work is from 0 to Y. Right??
and if the cylinder stand horizontally still with oild or water in it then the intergration is from the top part of th cylinder (the diameter)to the surface(diameter+ X), right??
and what if their is no oil in the cylinder? what would the intergration be?
Hi d_b! :smile:
I don't follow … if there's no oil, what are you plumbing? :confused:
hm...good question. i totally didn't see that. Anyhow still if i was to left an object up then the work that is going to be done on it is up to the depth of the oil?
i read i few other site and it seems that every work that is done on the object is up to the line where the water or oil is (the intergration)but I'm just not sure how to picture that if the object is under the surface or some sort.
