How Far is the Spring Compressed by the Sliding Block?
The problem involves a 5.0 kg block sliding on a horizontal surface with a coefficient of kinetic friction, striking a massless spring. The questions focus on determining the compression of the spring and the minimum static friction coefficient required to keep the spring compressed.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the energy conservation approach, equating kinetic energy to spring potential energy and work done against friction. There are attempts to derive equations for both parts of the problem, with some confusion regarding the correct formulation of forces and energy relationships.
Several participants are actively engaging with the problem, providing different interpretations and equations. There is a mix of attempts to clarify the relationships between forces and energy, particularly in the context of static and kinetic friction. Some guidance has been offered regarding the balance of forces and the use of energy equations, but no consensus has been reached on the correct approach for part B.
Participants are grappling with the implications of static versus kinetic friction and the conditions necessary for the spring to remain compressed. There is an ongoing discussion about the correct application of work-energy principles and force balance in the context of the problem.
Bones
A 5.0 kg block slides along a horizontal surface with a coefficient of friction µk = 0.30. The block has a speed v = 2.1 m/s when it strikes a massless spring head-on (as in the figure).
http://www.webassign.net/gianpse4/8-18.gif
(a) If the spring has force constant k = 120 N/m, how far is the spring compressed?
(b) What minimum value of the coefficient of static friction, µs, will assure that the spring remains compressed at the maximum compressed position?
If µs is less than this, what is the speed of the block when it detaches from the decompressing spring? [Hint: Detachment occurs when the spring reaches its natural length (x = 0).]
a) -1/2(5.0kg)(2.1m/s)^2 + 1/2(120N/m)(x^2) = (0.30)(5.0kg)(9.8m/s^2)(cos 180)(x)
x=0.323m
b) I took u(5.0kg)(9.8m/s^2)(0.323m)(cos 180) = -1/2(120N/m)(0.323m)^2 which is not correct. Can someone help me get the correct equation??
Please help, I am really stuck!
Any help at all would be appreciated ;)
3. The Attempt at a Solution
x=0.323m
For a) I would write your equation as the KE of the mass = the work to compress the spring and the work against friction:
mV2/2 = kx2/2 + u*m*g*x
That yields for me 600x2 + 14.7x - 11.025 = 0
Using the quadratic formula that yields a different answer than you suggest.
For b) draw a force diagram.
The F = kx needs to balance the us*m*g
How did you get 600x^2 from 120x^2/2??
Sorry. Of course it is 60x2.
And that yields your .323 m
I am still not getting part B.
If it is at equilibrium then the frictional force (using the static coefficient) must be equal to or greater than the kx from the spring detent:
You were attempting to use the work relationship when you were asked what condition needed to be met for the forces to balance.
You would use the work energy relationship figuring the transfer of potential in the spring back to the kinetic and friction for the outward rebound.
So umgx=1/2kx^2?
Bones said:
So umgx=1/2kx^2?
No. Not quite.
The excess of that is the kinetic energy remaining in the block.
mV2/2 = kx2/2 - u*m*g*x
Don't forget to answer the static coefficient part of the problem.
How do I figure that part out?
I've already told you. Look back at the earlier posts.
So umg=1/2kx^2
So umg=1/2kx^2
No. 1/2 k*x2 is WORK. Units are N-m
u*m*g is Force. Units are N.
The force of a spring is given as F = kx. Units are N.
So it's u*m*g = k*x
Thank you!
Bones said:
Thank you!
No problem then.
Cheers.
  • · Replies 27 ·
11K
  • · Replies 16 ·
