How Does Friction Affect Spring Compression and Block Displacement?
The problem involves two identical massless springs and a block on a level track, with a focus on how friction affects spring compression and block displacement. The scenario includes a block compressed against a spring, released, and moving over a section of track that has kinetic friction.
  • Participants discuss the energy considerations involved, particularly how friction affects the work done on the block as it moves over the frictional section. There are attempts to relate the work done by friction to the energy stored in the spring.
Some participants have provided guidance on calculating the work done by friction and how it relates to the spring's potential energy. There is an acknowledgment of confusion among some participants regarding the problem's requirements and the calculations involved.
The discussion highlights the specific conditions of the problem, including the frictional area and the parameters of the springs and block. There is an emphasis on understanding the energy transformations and the impact of friction on the system's behavior.
Jessicaelleig
Two identical massless springs of constant k = 200 N/m are fixed at opposite ends of a level track, as shown in Figure P5.62. A 5.90 kg block is pressed against the left spring, compressing it by 0.150 m. The block (initially at rest) is then released, as shown in Figure P5.62a. The entire track is frictionless except for the section between A and B.
Figure P5.62.
Given that the coefficient of kinetic friction between block and track along AB is µk = 0.0800, and given that the length AB is 0.238 m,
(a) determine the maximum compression of the spring on the right (see Fig. P5.62b).
(b) Determine where the block eventually comes to rest, as measured from A (see Fig. P5.62c).
If anyone can provide some guidance, I would appreciate it.
Thank you
Figure P5.62.
Thank you
Since you only have the one area that has friction - where energy can be robbed from the block - then what you are interested is how much 1 pass over the patch of friction will take away.
W = F*d
so your work each pass removed is u*m*g*d = .08 * 5.9 * 9.8 * .238
The work for the Spring is kx2/2 so knowing how much work goes to KE then gets subtracted each pass over the patch you can figure the rest.
thanks! anything else? I am so confused
Any more and I'd be giving you the answers wouldn't I?
And gosh darn it I can't take your tests for you. So what good what that be?
Just draw a diagram and figure it out.
  • · Replies 27 ·
11K
  • · Replies 58 ·
  • · Replies 16 ·
