Selecting Marbles from a Bag: Combinatoric Question
  • Thread starter Thread starter phoenixy
The discussion revolves around a combinatorial problem involving the selection of nine marbles from a total of twelve, categorized into four colors with three marbles each. Participants are exploring the relationship of this problem to the inclusion-exclusion principle and various combinatorial arrangements.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants present different cases for grouping the marbles based on color combinations and question the validity of their approaches. Some suggest simplifying the problem by considering the selection of the remaining marbles instead of the chosen ones. Others explore the use of combinatorial formulas to calculate arrangements.
The discussion is active, with participants sharing their reasoning and methods. Some have proposed alternative approaches to the problem, while others are questioning the correctness of their calculations and interpretations. There is no explicit consensus on the best method yet.
Participants are working under the constraints of a homework assignment, which may limit the methods they can use or the assumptions they can make about the problem setup.
phoenixy
I had been thinking about this one for awhile now but somehow couldn't come up with anything
Q: Number of ways to select nine 9 marbles from a bag of twelve, where 3 are red, 3 are green, 3 are white, 3 are blue
This question is in the inclusion & exclusion section(but I can't figure out how it's related to I & E..)
any suggestion?
any suggestion?
The way I did it was to figure out the different ways you could have your chosen combinations, e.g. three groups of 3, two groups of 3, one group of 2, and another group of 1. Each "group" has only the same coloured marbles. I found the different types of combinations you could end up with, then figured out how many ways you could assign colours to the groups in the combinations. So, for example, the combination that has three groups of three can be done in 4C3 ways ("four choose three"). If you are going to have three groups of three marbles, each marble in a group being the same colour, and you're starting out with four such groups in the bag, then it's really just like choosing 3 colours out of a set of 4, so 4C3.
Find the different types of combinations, then find the number of ways you can choose the colours for those combinations, and add them up.
OK
Here is what I came up with
To get 9 marbles out of 12(4 groups of 3 with diff color), the group arrangement is
Case 1: 3 3 3 0
Case 2: 3 3 2 1
Case 3: 3 2 2 2
so the answer is Case 1 + Case 2 + Case 3
for Case 1, it's simply c(4,3) (4 chooses 3)
for Case 2,
The color combination is
4!/2!
since there are 4 elements and 2 of them are the same.
The marble combination is
c(3,3)*c(3,3)*c(3,2)*c(3,1) = 9
so Case 2 = 9 * 4!/2! = 54
for Case 3,
4!/3!
c(3,2)*c(3,2)*c(3,2)*c(3,3) = 27
so Case 3 = 4 * 27 = 108
The answer is
4+54+108 = 166
makes sense?
I have a simpler approach to this (which I hope is valid).
First, if you select a group of 9 out of 12 marbles & place them on your left, there are 3 marbles on your right. So the number of ways to select the 9 marbles should be the same as the number of ways to select the 3 marbles. That's a much simpler problem, which with these numbers you can simply count. I make it out to be 20.
As to an analytical solution: when I turn it around this way, the number of marbles I'm selecting is no more than the total number of each color that is available: 3. I want to choose 3 marbles out of 4 possible colors and there are 3 of each color available so there is no restriction on repetition.
Think of the 4 colors as a row of 4 bins into which I will drop my marbles. There are 3 dividers separating the bins, so using | to represent the dividers and * to represent the marbles, it looks sort of like this:
Now the problem is reduced to finding the number of ways to select the positions of the 3 stars out of 6 possible positions. That's just 6C3:
[tex]\frac{6!}{3!3!} = 20[/tex]
PS: I have shamelessly stolen this "bins and stars" explanation from Kenneth Rosen's Discrete Mathematics and Its Applications. I hope I am applying it correctly.
:wink:
phoenixy said:
OK
Case 1: 3 3 3 0
Case 2: 3 3 2 1
Case 3: 3 2 2 2
This is right so far.
for Case 2,
4!/2!
for Case 3,
4!/3!
The answer is
4+54+108 = 166
makes sense?
The rest is wrong. This was my approach to case 3: start by choosing the colour that that would correspond to the "3" in "3 2 2 2". There are 4 ways you can do that. Notice that you now have 3 colours to choose from, and want to put them into three same-sized groups, so there's really only one way to choose the rest. So, for Case 3, you should get 4.
Here's another way of thinking about it. Say you have four colour-buckets. In each bucket, you will put some number of marbles. The number of marbles will either be 3-3-3-0, 3-2-2-2, or 3-3-2-1. For 3-3-3-0, putting those four numbers in four buckets can be done in 4! ways, but since you have 3 similar elements, divide by 3!, giving 4. For the case where you have 3-2-2-2, you get the same thing, 4!/3! = 4. Finally, you have four numbers, but two of them are the same (the two 3's) so 4!/2! gives 12. This method may have been what gnome said, I only glanced at it. Whether you do it this way, the way I originally suggested, or his way, you will get 20.
Thanks!
argg, don't know how came up with the marble combination crap. I would had the right answre if it's left out.
