Thread Closed
Variance
Share Thread
Oct21-08, 01:51 PM   #1
Variance
X1 and X2 are independent random variables. They both have the same mean (mue). Their variances are s1^2 and s2^2 respectively, where s1^2 and s2^2 are known constants. It is proposed to estimate mue by an estimator T of the form T=c1X1 + c2X2.
Show that T will be unbiased if c1 + c2=1
and find an expression for var(T) in terms of c1, s1^2 and s2^2.
(assuming c1+c2=1)
2. Relevant equations
3. The attempt at a solution
I showed that T will be unbiased if c1+c2=1
For the next part this is what i did:
var(T) = var(c1X1+c2X2)
var(c1X1+c2X2) = E[(c1X1+c2X2)^2] + {E[c1X1+c2X2]}^2
and then after expanding and simplifying, i got:
var(T) = 2(mue)^2(c1^2 + 2c1c2 + c2^2)
I can easily change c2 in terms of c1 but how do put in terms of s1^2 and s2^2 as this is what they are asking for??
Thank you
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Oct21-08, 03:11 PM   #2
Recognitions:
Homework Helper Homework Help
If X, Y are independent random variables, and a, b are real numbers, then
Var(aX + bY) = a^2 Var(X) + b^2 Var(Y)
Apply this to the setting of your problem.
Note that, relating to your work,
Var(W)
does not equal
E(W^2) + (E(W))^2
so your formula would not get you to the desired result.
Oct21-08, 03:18 PM   #3
Thank you v much.
I should have known that Var(aX + bY) = a^2 Var(X) + b^2 Var(Y) !!!
But how come for this question
Var(W)
does not equal
E(W^2) + (E(W))^2
Oct21-08, 03:25 PM   #4
Recognitions:
Variance
Var(W) = E((W - mu_w)^2) = E(W^2 - 2Wmu_w + (mu_w)^2) = E(W^2) - 2(mu_w)^2 + (mu_w)^2 = E(W^2) - (mu_w)^2
for any random variable W. I believe you just missed a sign.
Sometimes, after staring at a problem for some time, our minds see what we want them too rather than what we've actually written - it happens to me a lot.
Oct21-08, 03:31 PM   #5
Oh ofcourse...it's minus...silly me.
What u said is SO TRUE.
Thanks v much.
Thread Closed
Similar Threads for: Variance
Thread Forum Replies
variance of a sum Set Theory, Logic, Probability, Statistics 7
QM - variance Advanced Physics Homework 1
Variance of variance Set Theory, Logic, Probability, Statistics 4
Help on Variance of Variance Calculus & Beyond Homework 1
Variance Set Theory, Logic, Probability, Statistics 9
