Coefficient determination for the underdamped oscillator
The discussion focuses on determining the coefficients A1 and A2 for the underdamped oscillator described by the equation x(t) = exp(-Bt)*[(A1)cos{(w1)t} + (A2)sin{(w1)t}]. The user successfully identifies that at t = 0, x(0) = x0 = A1, and derives the velocity equation v(0) = v0 = -B(A1) + A2(w1). The challenge lies in expressing A1 and A2 solely in terms of x0, v0, and w1, without making approximations regarding the damping factor B. The user questions the feasibility of this task, emphasizing that B is a constant parameter independent of initial conditions.
  • Understanding of underdamped oscillators and their mathematical representation.
  • Familiarity with differential equations and their solutions.
  • Knowledge of the relationship between position and velocity in oscillatory motion.
  • Basic grasp of damping factors and their implications in physical systems.
  • Study the derivation of the general solution for underdamped oscillators in detail.
  • Explore methods for solving linear differential equations with constant coefficients.
  • Investigate the physical significance of damping factors in oscillatory systems.
  • Learn about the implications of initial conditions on the behavior of oscillators.
Students studying classical mechanics, physicists analyzing oscillatory systems, and engineers working with damped oscillators in various applications.
buffordboy23
The general solution of the underdamped oscillator is given by
Solve for x0 = x(t=0) and v0 = v(t=0) in terms of A1 and A2. Then solve for A1 and A2 in terms of x0, v0 , and w1.
w1 = sqrt{ (w0)^2 - B^2 }
At t = 0, x(0) = x0 = A1.
Now taking the derivative w.r.t time gives,
v(t) = -Bexp(-Bt)*[(A1)cos{(w1)t} + (A2)sin{(w1)t}] + exp(-Bt)*[(A2)(w1)cos{(w1)t} - (A1)(w1)cos{(w1)t}]
So, v(0) = v0 = -B(A1) + A2(w1).
Am I being retarded somewhere, or is it impossible to solve for A1 and A2 in terms of x0, v0, and w1 only? The problem never indicates anything about using approximations, such as B is close to zero, so v0 can be approximated as v0 = A2(w1). Does this seem like the only route to go with? Thanks.
By the way, Latex isn't working, so I had to use this convoluted notation.
B does not depend on initial conditions. It's a parameter of the system(as w is).
B is a damping factor, depends on viscosity of the medium, shape of the oscillator... will be the same no matter what initial conditions.
