Acceleration due to Gravity: calculate initial velocity
The problem involves a pole vaulter's motion as she travels upward and then downward, with a focus on calculating the initial velocity required to achieve this motion. The subject area pertains to kinematics and gravitational acceleration.
  • Mixed
  • Participants discuss the interpretation of the distance traveled, questioning whether the total distance or the displacement should be used in calculations. Some suggest reconsidering the initial equation used and exploring the time taken for each segment of the journey.
The discussion is ongoing, with participants exploring different interpretations of the problem and offering alternative approaches. There is no explicit consensus yet, but several lines of reasoning are being examined.
Participants note potential confusion regarding the use of total distance versus displacement in the calculations, as well as the implications of the time taken for each part of the journey.
Archedcutie
1. Homework Statement
A Pole vaulter leaves the ground to travel 4.0 m up and over the bar, and then another 4.0 m back to the ground. It takes 1.81 s for the whole trip. Caculate the velocity with which she left the ground.
2. Homework Equations
Well the equation I used which I saw in my textbook was, v1[initial speed] = d-1/2[g][t]^2
3. The Attempt at a Solution
I subbed it in as v1= 8m- 1/2 [9.8N/kg][1.81s]^2
and I didn't get 8.8m/s [up] like the answer at the back of the textbook :(
I think 8m in the equation is wrong. How I read the problem is she travel up (y) 4 m, and then down 4 m, so the d = 4m. maybe that is it? I am not too sure, but maybe it's worth a try.
Hi,
if you forget 'THE equation' approach and think back to first principles.
The whole journey takes 1.81 s.
How long will the up part of the journey take?
The vaulter starts at a speed v, vertically.
At the peak of the vault what is their vertical speed?
now, you should be able to work it out as you have end speed, acceleration, distance and time!Cheers
on the aimslin22 front:
they travel up 4m and down 4m - so their overall displacement (Not distance) is...
  • · Replies 17 ·
