Simple Harmonic Motion Question
The discussion revolves around a problem related to simple harmonic motion (SHM), specifically examining the relationship between mass, spring constant, and angular frequency in the context of a mass-spring system. The original poster seeks to confirm a solution for the SHM equation and establish a relationship involving the parameters k, m, and w.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the differentiation of the SHM equation and its validity. Questions arise regarding the relationship between forces acting on the mass, particularly how gravitational force and spring force interact. Some participants attempt to derive relationships between k, m, and w^2, while others express uncertainty about their reasoning.
Participants are actively engaging with the problem, offering various interpretations and approaches to relate the parameters involved. Some have provided insights into Newton's second law and the nature of forces in the system, while others are questioning assumptions about the orientation of the spring and its implications for the analysis.
There is a noted ambiguity regarding the orientation of the spring (horizontal vs. vertical), which affects the analysis of forces. Participants are also grappling with the implications of the restorative force in relation to the parameters of the system.
theneedtoknow
A weight of mass m is placed on a string. as a result it exerts a force equal to xk that tends to reduce x, where k is the spring constand and x is the distance from the equilibrium position of the spring.
1. Confirm that x = Asin(wt+ f) is indeed a solution of theequation of SHM. (given below)
2. Write down the relationship between k, m, and w^2.
d^2 / dt ^ 2 = -w^2 * x
1. Well i got this part by differentiating x = Asin(wt+f) and indeed it is a solution
2.
I have no idea how to do this part...
All i can think of is that at the peaks and troughs of oscillation a is zero so the forces mg and xk must be equal but that doesn't really help me relate them in general
Think in terms of Newton's second law of motion.
Well I'm tryin to...but not sure how...
Fnet = mg + xk = ma
(ma - mg) / k = x
well this is tthe relationship between m and k and... I doubt its even right... and i have no idea how to go to relate to w^2 of all things
How did the mg come in?
Anyway, Fnet is also equal to m(d2x/dt2).
d^x / dt^2 = a(t) right?
so would it be f = ma
so Fnet = m * d^2/dt^2?
crap, i misread the first time lol
theneedtoknow said:
Well isn't mg the force of gravity on the mass?
So the enet force would be force of gravity + resporing force Fnet = mg + xk
It is not mentioned that the spring is hanging vertically. You must therefore assume that is placed on a smooth horizontal surface. In that case, the force due to gravity and the normal force due to the surface cancel each other.
And how come Fnet = d^2/dt^2? I am missing the link between the two , can you help me out to relate them?
Please look at the equation I typed once more. If it is still not clear, read your textbook (on Newton's second law).
cause if Fnet is indeed equal to that, then the relationship should be
mg + xk = -w^2x and then i guess the final relationship between those would be
k = (-w^2x - mg )/x
m = (-w^2x - xk ) / g
w^2 = (-mg - xk )/ x
or...no?
No.
OK so then for a horizontal string :
kx = -mw^2x
so they are related by
k = -mw^2 (i think)
But can you help me figure out what the answer would be with a vertical spring as well cause now I am curious...
Would it be mg + xk = -mw^2x?
kx = -mw^2x
There is a rather important detail missing.
Again, the same detail is missing here. But as it turns out, the relation between these three quantities (omega, k and m) is the same no matter how the spring is oriented. This of course assumes ideal conditions, such as a negligible mass for the spring, etc.
is it that its a restorive force so it shud be k = mw^2?
Exactly.
ahhh excellent thanks a lot for all the help
  • · Replies 51 ·
  • · Replies 17 ·
