How Do You Calculate Distance When Velocity Changes?
The discussion revolves around calculating the distance traveled by a plane that accelerates from an initial velocity of 270 m/s at a rate of 28 m/s² over a time period of 9.8 seconds. Participants are exploring the implications of changing velocity during this time frame.
  • Participants discuss the calculation of final velocity and express confusion about multiplying this velocity by time to find distance. Some suggest using sketches to visualize the problem, while others emphasize the importance of understanding the changing velocity rather than applying constant velocity equations.
There is an ongoing exploration of the concepts involved in the problem, with some participants offering guidance on the need to consider the acceleration's effect on distance. Multiple interpretations of the problem are being discussed, and while some participants express confusion, others have begun to articulate their understanding of the distance calculation.
Participants are grappling with the implications of changing velocity and the appropriate equations to use in this context. There is a mention of avoiding straightforward application of distance formulas without considering the acceleration involved.
bigzee20
A plane is moving at 270 m/s accelerates at 28 m/s ^2 for 9.8s. How far would it have traveled in the time.
using vi + a(t) i was able to get its final velocity 544.4m/s but when i multiply it by 9.8s it tells me that is wrong what am i doing wrong? thanks
For what length of time does the plane travel at a speed of 544.4 m/s?
9.8s but when i multiply it by 544.4 m /s its wrong??
What speed did the plane have at the start of the 9.8s? Try doing a before and after sketch with the plane's speed labelled each time.
Iam still confused lol
a. What speed was the plane going at right at the start of the question?
b. What speed was the plane going at right at the end of the question, 9.8 s later?
c. What do you think it was doing in between :-)
(Once you've got that conceptually, you can start to think about distance. If you just plug and chug with an equation for the distance right now, you'll be confused about a lot of things later in your course.)
I got it man ! woot.
Here it is d = Vi(t)+1/2a(t)^2
therefore 270(9.8) + 1/2(28)(9.8)^2
= 3990.56 m
THANKS heth
Nice one! The key is realising that the plane's velocity is changing all the time, so you can't use an equation that assumes the velocity is constant.
  • · Replies 17 ·
