What is the limit for Sin(1/x^n)?
  • Context: Undergrad
  • Thread starter Thread starter janakiraman
    Limits
The discussion revolves around the limit of the function Sin(1/x^n) as x approaches a specific value, particularly focusing on the behavior of the function near x=0. Participants explore the implications of oscillation in the function and how to calculate limits for specific values like x=0.1, as well as for different powers of n.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant notes that the limit for Sin(1/x) is not defined at x=0 due to oscillation, and questions how to calculate the limit at x=0.1 and for other powers of n.
  • Another participant asserts that since Sin(x) is continuous, the limit can be taken inside the sine function for values other than zero, providing an example with x=0.1.
  • A later reply acknowledges a realization of a mistake in the initial question and inquires about the general applicability of taking limits inside continuous functions.
  • Another participant confirms that taking the limit inside the sine function is indeed a characteristic of continuous functions.
Participants generally agree on the continuity of the sine function and the ability to take limits inside it for values other than zero. However, the initial question regarding the limit at x=0 remains unresolved, with ongoing exploration of the behavior of the function at specific points.
The discussion does not resolve the implications of oscillation for the limit at x=0, nor does it clarify the behavior of Sin(1/x^n) for all n in detail. There are also assumptions about the continuity of functions that are not explicitly defined.
janakiraman
Hi
I have been trying to work with limits and i came across a problem where it was defined that the limit for Sin(1/x) is not defined at x=0. Well i completely understand that part because the function oscillates for any small limit near 0. But i don't really understand how to calculate the limit for x for example at 0.1. Because the function still oscillates and what would be the ideal limit value that i need to take so that the function will proceed towards value sin(1/0.1)? And how to calculate similarly for sin(1/x^2), sin(1/x^3) etc until Sin(1/x^n) for x=0.1 from the definition of limits.
I tried to do a MATLAB code and generate graph to see if there is a pattern in oscillation, but unfortunately i could not decode anything. I have attached the graph here, the blue curve indicates sin(1/x), red for sin(1/x^2), green for sin(1/x^3) and black for sin(1/x^4).
P.S: In my opinion i felt this problem does not fall into homework questions, but I'm extremely sorry if someone else feels that way
Sin(x) is a continuous function so
[tex]\lim_{x\rightarrow x_0} sin(\frac{1}{x})= sin(\lim_{x\rightarrow x_0}\frac{1}{x})[/tex]
That inner limit exist for all x0 except 0. The limit as x approaches 0.1 is just sin(1/0.1)= sin(10).
If x is close enough to 0.1, for example if 1/(0.1+ [itex]\pi[/itex]/2)< x< 1/(0.1- [itex]\pi[/itex]/2) on your graph (x, sin(1/x) ) is on ONE of the many oscillations shown on your graph and the others don't matter.
hey thank you very much. infact even i realized the mistake in my question after i asked it :). But another question is the way you took the limit inside sin is possible for all continuous curves right?
Yes, that's pretty much the definition of continuous!
