How Small Should Delta Be for a Given Epsilon in Calculus?
  • Thread starter Thread starter musicfairy
    Delta Epsilon
The discussion centers on determining the appropriate value of delta for a given epsilon in the context of the limit of the function f(x) = x³ + x² + x + 1 as x approaches -1. The user initially calculated delta as 0.326 based on incorrect intersection points from their graphing calculator. However, it was established that the correct approach requires factoring the polynomial and ensuring that |f(x)| < epsilon, with delta needing to be significantly smaller than epsilon to satisfy the limit definition accurately.
  • Understanding of limits in calculus
  • Familiarity with epsilon-delta definitions of limits
  • Ability to factor polynomials, specifically cubic functions
  • Proficiency in using graphing calculators for function analysis
  • Study the epsilon-delta definition of limits in calculus
  • Learn how to factor cubic polynomials effectively
  • Explore the use of graphing calculators for analyzing function behavior near limits
  • Investigate how to determine appropriate delta values in limit problems
Students of calculus, mathematics educators, and anyone seeking to deepen their understanding of limits and epsilon-delta proofs in mathematical analysis.
musicfairy
I don't know how yor format this, so:
x3 + x2 +x +1
The limit of that function = 0 as x approaches -1
What's the greatest value of delta when epsilon = 0.1?
This is what I tried to do:
|x3 + x2 + x + 1| < 0.1
-0.1 < x3 + x2 + x + 1 < 0.1
-1.1 < x3 + x2 + x < -0.9
In my calculator I plotted y = f(x), y = -1.1, and y = -0.9
The intersect are at x = -1.379 and x = -1.326
So I plugged them in this equation.
0<|x + 1|<delta
|-1.379 + 1| < 0.379
|-1.326 + 1| < 0.326
So I pick delta = 0.326 because it's smaller.
Now can someone please tell me everything that went wrong and offer any advice on how I could understand this?
x3 + x2 +x +1
0<|x + 1|<delta
|-1.379 + 1| < 0.379
|-1.326 + 1| < 0.326
What exactly was your f(x)? I do exactly what you say you did and I do NOT get -1.379 and -1.376. For one thing, x= -1 is NOT between those values- they can't possibly be right!
Your delta is way too big. f(-1.326) = -0.8992, and f(-0.674) = 0.474094. Here x is within .326 of -1 (-1 - .326 and -1 + .326), but the function values are not within .1 of zero.
When you plotted f(x) on your calculator, did you use f(x) = x^3 + x^2 + x + 1? You also show x^3 + x^2 + x in one of your inequalities, so I'm not sure whether you might have used that one.
You should factor x^3 + x^2 + x + 1 into (x + 1) times the other factor.
You want |x^3 + x^2 + x + 1| < epsilon
so |x + 1|* |something| < epsilon
You can tie that inequality to one involving |x + 1| if you replace |something| above with a value that's guaranteed to be larger, for all values of x on some reasonable interval.
As a hint, delta needs to be quite a bit smaller than epsilon, like some fraction of it.
  • · Replies 31 ·
  • · Replies 26 ·
