Working on a large battery system
  • Context: Undergrad
  • Thread starter Thread starter sheldon
    Battery System
The discussion revolves around troubleshooting issues in a large battery system, specifically focusing on ground faults and unexpected voltage readings. Participants explore the challenges of diagnosing problems in a floating ground system, the behavior of battery cells, and the implications of phantom readings during measurements.
  • One participant describes experiencing ground faults in a floating battery system and questions the reliability of voltage measurements in identifying the source of these faults.
  • Another participant suggests that floating faults may exist, indicating that understanding the system's operation is crucial for troubleshooting, rather than relying solely on measurement tools.
  • A suggestion is made to use a half-split method for troubleshooting, which involves measuring voltages in segments to isolate the fault location.
  • One participant mentions that visual inspection of batteries can help identify leaks, which may contribute to the issues being faced.
  • Another participant recommends using an oscilloscope to detect RF oscillations that could complicate the troubleshooting process.
Participants express varying opinions on the effectiveness of different troubleshooting methods and the nature of the faults. There is no consensus on a single approach or understanding of the phenomena being discussed.
Participants acknowledge that the behavior of the battery system may not conform to standard troubleshooting procedures, and that experience plays a significant role in diagnosing such issues. The discussion highlights the complexity of floating ground systems and the potential for misleading measurements.
Individuals working with battery systems, electrical engineers, and those interested in troubleshooting electrical faults may find this discussion relevant.
sheldon
You may think I am in the wrong area for this thread, but this is not about ghosts per say. I was working on a large battery system that is suppose to be floating in referance to ground. These batteries are gel cells and are haveing problems with leaks. These leaks are causing ground faults in the system. I was trying to troubleshoot the problem using a multimeter measuring the voltage from ground to the posts on the batteries. In theory the battery that has the least voltage or where the voltage flips from posative to negative is the location of the ground fault. I found several readings like this and thought I found my ground fault. I left and came back and the low or flipped point has moved without any interference from me. I was confused and thought there was more to this that meets the eye, so I conducted some research and found out that this has been labeled as ghost troubleshooting and no true procedure can accomplish pinpointing the problem and only experience can make it happen. Has anybody herd of this? I realize that ground is a general term as far as voltage potential zero. I would still think the ground fault would still be in the same location though? Any wizzards out there no the physics behind this?
sorry for the wizzard reply, can anybody help with this
Well, if you have floating ground, and you have ground faults, then it seems natural that you have floating faults, isn't it?
There are faults that cannot be easily found by meters, good understanding about how it works and what can go wrong is needed. For eg. audio amp can loose all of its power and get hot. You start measuring it, and it recovers immediately. As soon as you touch it with a meter, it heals. Actual cause occurs to be feedback induced oscillation at very high (radio) frequencies. You not only hardly detect it due to low amplitude, but you simply don't even think about it, its audio amp afterall. Meter merely shuts down the oscillation. Knowing this is part of 'experience'.
There is hardly any true procedure to pinpoint the source of a problem, other than 1) understand how it works, 2) understand what can go wrong, 3) eliminate all that can go wrong
So, without understanding schematic its hard to tell anything. The more experience you have, the less 'eliminate all' you'd have to exercise, you'd go directly to source of problem 'by intuition'.
how many batteries are there?
R they in series or parallel? beisides gnd is gnd but the best way to troubleshoot this is by using a half split method. that is mewasuring in the middle to find the fault, if its in the middle 1/2 split that till you find where the voltage drops. I am thinking a leaking battery, you should be able to visually see this to locate your battery problem, sir.
Let me know if this helps?
Dx :wink:
Dx :wink:
Yes I have already located the problems via careful inspection and cleaning. I am just trying to understand what caused the phantom readings. Your right about the how to troubleshoot the problem and it works to a point. Thanks for your help
I've worked with amps too
and when things get really weird put a good o'scope on it, or even near it. If it has RF oscillations you can find them.
weird
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 28 ·
