How does one calculate the distance (or length) on the ground
  • Context: Graduate
  • Thread starter Thread starter Pollock
    Ground Length
The discussion focuses on calculating the distance on the ground corresponding to one minute or one second of arc at specific points on the Earth's surface, considering latitude and longitude. It explores both simplified and more complex models of the Earth's shape, including the implications of using a spherical versus a geoid model.
  • One participant asks how to calculate the distance on the ground for one minute or second of arc based on latitude and longitude, and inquires about obtaining an accurate Earth radius as a function of latitude.
  • Another participant suggests that assuming the Earth is a sphere allows for a simple calculation of arc length, but acknowledges that a more complete answer requires considering the Earth's geoid shape.
  • It is noted that the distance equivalent to one degree of arc is consistent across latitudes when assuming a spherical Earth, but the distance for one degree of longitude varies due to the decreasing size of circles of latitude towards the poles.
  • A later reply emphasizes that the arc length for a degree change in latitude remains nearly constant across the Earth's surface, explaining the distinction between geodetic latitude and the angle subtended by the Earth's equatorial plane.
Participants express differing views on the implications of using a spherical model versus a geoid model, and there is no consensus on the best approach to calculate distances based on latitude and longitude.
Participants highlight the need for precision in defining latitude and the potential inaccuracies when using simplified models. The discussion does not resolve the mathematical complexities involved in these calculations.
Pollock
How does one calculate the distance (or length) on the ground suspended by one minute of arc (or one second of arc) at a particular point on the Earth's surface,given its latitude/longitude in degrees/ minutes /seconds ?.Where would one get the Earth radius of sufficient accuracy as a function of latitude ?.
Pollock
For a simple answer you can assume the Earth is a sphere then the length of an arc segment is failry simple to work out.
More complete answer require more terms to account for the Earth's shape (geoid) see http://en.wikipedia.org/wiki/Latitude
The distance on the ground equivalent to one degree of arc will be the same at any latitude (assuming the Earth as a perfect sphere).But this will not be so for the distance equivalent to a degree of longitude as circles of constant latitude get smaller towards the poles.How does one take account of this to calculate distance on the ground in terms of both latitude and longitude anywhereon the Earth's surface
The arc length of one degree change in latitude is very, very close to constant everywhere on the non-spherical surface of the Earth. The reason why is that latitude of a point on the surface is not the angle subtended between the Earth's equatorial plane and the line connecting the center of the Earth and the point in question. The latitude of a point is instead the angle subtended between the Earth's equatorial plane and the line defined by the normal to an idealization of the Earth's non-spherical surface. This angle is more precisely called the geodetic latitude of the point. The word "latitude" without a qualifier means geodetic latitude.
  • · Replies 18 ·
  • · Replies 16 ·
15K
  • · Replies 16 ·
  • · Replies 42 ·
