Impulse in Inelastic Collisions
The discussion revolves around calculating the impulse exerted by the ground on a rubber ball during an inelastic collision. The problem involves determining the downward and upward momentum of the ball after it is dropped from a height and rebounds to a lower height, while considering the effects of gravity and momentum change.
  • Mathematical reasoning, Assumption checking, Problem interpretation
  • Participants discuss the calculation of downward and upward velocities using kinematic equations and the subsequent determination of momentum. There are questions about the correctness of momentum calculations and the use of average velocity versus instantaneous velocity. Some participants explore the relationship between impulse and force over time.
Participants are actively engaging in clarifying their calculations and reasoning. Some guidance has been offered regarding the correct approach to calculating momentum and impulse, with emphasis on the need to consider the velocities just before and after the collision. There is acknowledgment of mistakes and a collaborative effort to refine understanding.
Participants are working under the assumption that there is no air friction and are exploring the implications of this assumption on their calculations. There is also a focus on the signs of velocities when calculating impulse.
avenkat0
A 0.291 kg rubber ball is dropped from a height of 3.72 m, and it rebounds to a height of 2.88 m. Assume there is no air friction.
a) Find the magnitude of the impulse exerted by the ground on the ball.
Vf^2=V0^2+2as
MV=P
DeltaP=I
I used Kinematic equations to find out the the Vf down of the ball was 8.54
and then Vavg=4.27... MVdown=1.242
MVdown-MVup = Impulse
MVup i did the same thing i got 1.093
Ended up wrong
Thank you for your help
Your value for the downward momentum is not correct. All you need to do is to multiply the downward velocity by the mass of the ball and this will give you the momentum.
this is how I figured out the downward velocity:
Since there is a netforce and an acceleration of g, it's not a constant velocity therefore I found the Vavg by finding time first x=V0t+.5gt^2 and then with t finding Vf=Vo+gt then Vavg=(Vo+Vf)/2
Is there a flaw in my reasoning
And I did the same for upward Vavg to find the difference in momentum to find the impulse
You calculated the velocity correctly, but miscalculate the momentum. As I said above, simply multiply the velocity by the mass to obtain the associated momentum.
Thank you... but if the velocity is correct: I am getting 4.27(Vavg)*.291(mass)=1.242 Kg m/s for down momentum? that's what i got earlier..
i simply multiply my avg velocity down with the mass of the object to get Magnitude down and then i find the Magnitude up and then find the difference of both to get the impulse?
avenkat0 said:
Thank you... but if the velocity is correct: I am getting 4.27(Vavg)*.291(mass)=1.42 Kg m/s for down momentum?
So therefore i simply multiply my avg velocity down with the mass of the object to get Magnitude down and then i find the Magnitude up and then find the difference of both to get the impulse?
There is no need to use the average velocity here. You want to know the change of momentum over the collision with the ground, not the change in momentum of the overall fall and rebound. Therefore, you only need the velocities just before and just after the collision. In other words, you need to use the final downward momentum and the initial upward momentum.
Does that make sense?
yesss! Thank you so much...
I forgot to realize that the Impulse is the integral of F dt from delta t right before and after the collision.
My pleasure :smile:
b) If the ground exerts an average force of magnitude 296 N on the ball, find the time the ball was in contact with the ground.
For this would i just take the impulse and divide it by the magnitude of force to get the time... since an Impulse is in N(s)
Sounds good to me :approve:
im getting .2981 for the impluse and .00100722 for the time and it seems to be wrong.
Vf(down)=8.54 Vo(up)=7.51 mass=.291 kg
These values are correct, but your calculated value for the impulse is not. You should be careful with your signs, notice that the upward velocity is in the opposite direction to the downward velocity.
thank you! that was a silly mistake...
thanks for all your help
No problem, it was a pleasure :smile:
  • · Replies 21 ·
