How Does Train Acceleration Affect Projectile Firing Angle for Maximum Distance?
The discussion focuses on determining the optimal firing angle (theta) for a projectile launched from a cannon on an accelerating train to achieve maximum distance. The projectile's horizontal velocity is expressed as vcos(theta) + vt, while its vertical velocity is vsin(theta). The acceleration of the train (a) plays a crucial role in the projectile's trajectory, particularly when considering scenarios where the train may overtake the projectile before it lands. A frame of reference moving with the train simplifies the calculations for both the train's and projectile's positions over time.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Basic knowledge of trigonometry, specifically sine and cosine functions
  • Concept of relative motion in physics
  • Explore the derivation of projectile motion equations under varying acceleration conditions
  • Study the effects of different angles on projectile range in a non-accelerating frame
  • Investigate the implications of relative motion in physics problems
  • Learn about advanced kinematic analysis techniques for non-inertial reference frames
Physics students, educators, and enthusiasts interested in the dynamics of projectile motion, particularly in non-inertial frames of reference, as well as engineers working on systems involving moving platforms.
Lamoid
A cannon on a train car fires a projectile to the right with speed v relative to the train, from a barrel elevated at angle theta. The cannon fires just as the train, which had been cruising to the right along a level track with speed vt, begins to accelerate with acceleration a. Find an expression for the angle at which the projectile should be fired so that it lands as far as possible from the cannon. You can ignore the height of the cannon above the track.
Ok, so I know in the x direction
the projectile has a constant velocity of vcostheta + vt
in the y direction
initial veloctity of vsintheta.
I've tried solving for t in the vertical direction and then substituting into the x direction kinematic formula but I am still not sure how to find theta for some maximum distance.
Also, the answer has a (the acceleration of the train) in it. I do not get at all why this is important unless it is talking about the case in which the a is so large that the train passes the projectile before it lands.
Thanks in advance.
Hi Lamoid! :smile:
Hint: assume that the initial speed of the train is zero (in other words, use a frame of reference at the same speed as the train).
Then caclulate the position of the train and of the projectile at time t. :smile:
  • · Replies 19 ·
28K
  • · Replies 18 ·
