Does the Prism Effect Influence the Color of Sunsets?
  • Context: High School
  • Thread starter Thread starter Tibriel
    Sky
The discussion centers on the influence of atmospheric conditions on the colors observed during sunsets, specifically contrasting the roles of scattering and refraction. It is established that the sky appears blue due to Rayleigh scattering, which preferentially scatters shorter blue wavelengths of light. During sunsets, the sun's light travels through a greater thickness of the atmosphere, resulting in the scattering of blue light and the predominance of red and orange hues. The prism effect, while relevant in light dispersion, does not directly influence the color of sunsets as the scattering process is the primary factor.
  • Understanding of Rayleigh scattering
  • Basic knowledge of light properties and wavelengths
  • Familiarity with atmospheric physics
  • Concept of light refraction and dispersion
  • Research the principles of Rayleigh scattering in detail
  • Explore the physics of light wavelengths and their interaction with the atmosphere
  • Study atmospheric optics and its effects on color perception
  • Investigate the role of light refraction in different atmospheric conditions
Students of physics, meteorologists, educators in atmospheric sciences, and anyone interested in the science behind natural phenomena like sunsets.
Tibriel
So the latest i read was that the sky is blue because that is the color of air, just like water is blue for the same reason. Now this short article i read also claimed that sunsets are red because of some property of light that causes it to show different colors when it transmits light as opposed to reflects light.
What troubles me in the last part is when you look at what prisms do. They split white light up into a rainbow of colors. And I thought that the atmosphere did likewise; when the sun's light hits the Earth's atmosphere at an angle we go from white light to reds, oranges.
So do they both play a part or does the way prisms work not play a part in why we see different colors at sunset?
Science news on Phys.org
The sky is blue because blue light is scattered best.
If you aren't looking directly at the sun then any light you see must have been scattered, since blue is scattered most - you see blue, the red light went straight through the atmosphere and out the other side.
As Tom Weller once said, "Why is the sky blue?" "Because it reflects the sea".
To add to mgb_phys, the same process explains why sunsets are red. When the sun is low in the sky, light travels through a lot of atmosphere, and much of the bluer light gets scattered away, leaving only the red.
  • · Replies 207 ·
16K
  • · Replies 40 ·
  • · Replies 34 ·
10K
  • · Replies 20 ·
