Un-damped Driven Harmonic Oscillator Question
The discussion revolves around the dynamics of an un-damped driven harmonic oscillator, specifically analyzing the equation of motion ma + kx = F(t) with a driving force F(t) = F-naught*sin(wt). The original poster seeks to find the displacement x(t) for t > 0 given initial conditions of x = 0 and v = 0 at t = 0.
  • Participants discuss the formulation of the solution in terms of complementary and particular solutions, with an emphasis on determining the coefficient A for the particular solution. There are questions about how to correctly apply initial conditions to the total solution.
Some participants have made progress in identifying the value of A for the particular solution and are working through the complementary part. There is acknowledgment of the need to apply initial conditions to the total solution, indicating a productive direction in the discussion.
Initial conditions x(0) = 0 and v(0) = 0 are emphasized as crucial for solving the problem, and there is a sense of urgency due to an impending deadline for submission.
Niner49er52
An un-damped driven harmonic oscillator satisfies the equation of motion: ma+kx=F(t) where we may write the un-damped angular frequency w-naught^2=k/m. The driving force F(t)=F-naught*sin(wt) is switched on at t=0. Find x(t) for t>0 for initial conditions x=0, v=0,at t=0.
I know that this can be written in terms of a complimentary and a particular solution and that the complimentary solution will be in the form x(t)=Asin(w-naught*t-delta) and that I need to consider a particular solution in the form x(t)=Asin(wt) and determine A by plugging x(t) into the differential equation.
The final answer is given as x(t)= -((F-naught/m)(w/w-naught)/(w-naught^2-w^2)) sin(w-naught*t) + ((F-naught/m)/(w-naught^2-w^2)) sin(wt)
Ive done similar problems that have worked out but for some reason I can't get this to come out right. It's driving me nuts I've been working on it all weekend and have to turn this work in tomorrow morning.
What do you get for A when you plug your particular solution into the DE...what does that give you for your general solution?
ok, i got that part. A will equal (F-naught/m)/(w-naught^2-w^2). I think I was just writing it wrong when I plugged into the DE. Now I just have to work through the complimentary part.
hmm, I know this should be the easy part but I'm stuck again! I can't seem to figure out how to solve for A in the complimentary part.
You'll have to use the initial condition that you were given: x(0)=x'(0)=0...remember that these condition apply to the total solution, not just the complimentary part.
thanks, that's what's probably getting me here. appreciate all the help
  • · Replies 16 ·
