Conservation of energy of a pendulum
The discussion centers on the conservation of energy in a pendulum system, specifically an 80cm long pendulum with a 0.60kg bob. The initial angle Theta is calculated using the equation Ui + Ki = Uf + Kf, leading to a height (h) of approximately 0.4m. This results in Theta being 60 degrees when the bob reaches a speed of 2.8m/s. For part b, the same energy conservation principles apply to find the angle when the bob's speed is 1.4m/s.
  • Understanding of basic physics concepts, particularly energy conservation
  • Familiarity with pendulum mechanics and motion
  • Knowledge of trigonometric functions, specifically cosine
  • Ability to manipulate and solve equations involving kinetic and potential energy
  • Study the derivation of the conservation of energy equation in mechanical systems
  • Learn how to apply trigonometric functions in physics problems
  • Explore the dynamics of pendulum motion and its applications
  • Investigate the effects of varying mass and length on pendulum behavior
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of pendulum motion and energy conservation.
maniacp08
An 80cm long pendulum with a .60kg bob is released from rest at an initial angle of Theta with the vertical. At the bottom of the swing, the speed of the bob is 2.8m/s.
a)what is Theta?
b)What angle does the pendulum makes with the vertical when the speed of the bob is 1.4m/s?Revelant equation:
Ui + Ki = Uf + Kf
I converted 80cm to .8m.
mgh + 0 = 0 + 1/2 m v^2
.60kg * 9.81 m/s * h = 1/2 .60kg * (2.8m/s)^2
I need to solve for h which is .3995922528 approx .4m
Length is .8m
h = L - Lcos Theta
.4m = .8m - Lcos Theta
.5 = Cos Theta
Cos^-1 = 60Is this correct?
and Part b is the same procedure correct?
a)what is Theta?
Ui + Ki = Uf + Kf
Length is .8m
h = L - Lcos Theta
.5 = Cos Theta
Looks OK so far.
And you can solve part b in a similar way.
  • · Replies 21 ·
  • · Replies 18 ·
