Velocity of Pendulum at a certain point
The problem involves a pendulum scenario where Tarzan swings from a cliff, and the objective is to determine the maximum tension in the vine at the lowest point of the swing after descending a certain height. The subject area includes concepts of forces, energy conservation, and dynamics.
  • Participants discuss the relationship between potential energy and kinetic energy as Tarzan descends. There is an exploration of how to derive the velocity at the lowest point of the swing using the height descended.
Some participants have offered insights into using energy conservation principles to relate the height descended to the speed of Tarzan at the bottom of the swing. There is an acknowledgment of the need to clarify the initial conditions regarding kinetic energy.
Participants are navigating the assumptions related to energy conservation and the initial state of motion, with some uncertainty about the initial kinetic energy at the top of the swing.
grantrudd
Tarzan, who weighs 668 N, swings from a cliff at the end of a convenient vine that is 23.0 m long (see the figure). From the top of the cliff to the bottom of the swing, he descends by 3.2 m.
If the vine doesn't break, what is the maximum magnitude of the tension in the vine?
http://capa-new.colorado.edu/hrw-lib/hrwpictures/8-38.jpg
F=ma
a_radial=v^2/r
i know that the max tension is at the bottom, so i made a force diagram at the bottom of the path, and summed the forces to get
F=T-mg
mv^2/r + mg= T
i found the mass, but my only missing variable is the velocity of the "pendulum."
i am completely stuck on this part. Thanks for any help!
Welcome to PF!
Can you think of anyways you can get V from this information "From the top of the cliff to the bottom of the swing, he descends by 3.2 m."
As energy is not lost nor created, Tarzan speed (kynetic energy) must come from another form of energy. In this case, he has descended 3.2m...
thanks for the welcome!
i have been thinking about it on the next homework problem actually, and i think it has something to do with conservation of momentum. something like:
1/2(mv^2)+mgy= 1/2(mv^2) +No potential at the bottom.
the initial velocity is 0, so the first initial kinetic energy is 0. is this reasoning right? or does he have some kinetic at the top?
i guess that was right. i got the problem right, so that should help me on a few other problems. i will probably be back here asking more questions later though!
10K
10K
