Why Does a Sodium Vapor Lamp Create a Dark Line at 589nm in the Spectrum?
The sodium vapor lamp emits light primarily at a wavelength of 589nm, which corresponds to the D-line doublet due to two closely spaced energy levels of sodium electrons. This results in a dark line in the continuous spectrum at 589nm, as photons of this specific wavelength are absorbed when light passes through sodium vapor. The absorption occurs because electrons transition between fixed energy levels, requiring a precise amount of energy that matches the energy of the 589nm photons. Thus, the dark line is a direct consequence of the absorption of these specific wavelengths by sodium atoms.
  • Understanding of atomic energy levels and electron transitions
  • Familiarity with the concept of photon absorption and emission
  • Basic knowledge of spectroscopy and continuous spectra
  • Knowledge of sodium vapor lamp operation and characteristics
  • Research the principles of atomic spectroscopy and energy level transitions
  • Explore the concept of spectral lines and their significance in identifying elements
  • Learn about the operation and applications of sodium vapor lamps in lighting
  • Investigate the effects of temperature on atomic emission and absorption spectra
Students studying physics or chemistry, educators teaching spectroscopy, and professionals working with lighting technology or atomic spectroscopy.
maxthedog
i understand that the wavelength given off by a sodium vapor lamp is 589nm, is this why there is a dark line in the continuous spectrum at 589mn?
Yes and it's actually two lines.
Yes - electrons move between fixed energy levels in the atom and need a fixed amount of energy to do this. This corresponds to a photon of a particular wavelength.
So if you heat up sodium (give it energy) the electrons can move from the one energy level to another and give off photons of exactly this wavelength.
Similairly if you send light of all wavelengths through sodium onyl those photosn with exactly the correct energy will be used to move an electron upto the other level. So the only photons with the correct wavelength will be absorbed and so missing from the continuum.
As GCT says, there is a further complication with Sodium the D line at 589nm is actaully two lines very close together because there are two energy states of the electron that are almost the same.
22K
