Understanding Fluorescence and pH Sensitivity of Fluorescein Molecule
  • Thread starter Thread starter Bridget
    Fluorescence
The discussion revolves around the fluorescence properties of the fluorescein molecule, particularly its pH sensitivity in terms of both absorbance and fluorescence intensity. Participants explore whether fluorescein should inherently exhibit pH sensitivity in fluorescence if its absorbance is pH sensitive, and they examine the implications of isosbestic points in this context.
  • One participant asserts that fluorescein emits fluorescence and questions the lack of pH response in fluorescence intensity despite observing an emission peak.
  • Another participant notes that the absorption and emission peak intensity changes with pH depend on the specific wavelength being examined, mentioning the existence of an isosbestic point for fluorescein's absorbance.
  • A participant raises the question of whether the presence of an isosbestic point for absorbance implies a similar point for fluorescence, expressing uncertainty about the literature on fluorescein's fluorescent properties.
  • Concerns are raised about the concentration of the fluorescein solution potentially affecting the observed fluorescence response, with a suggestion to investigate absorbance at different dilutions.
  • Participants discuss the implications of Beer's law and its nonlinearity in relation to both absorbance and emission, suggesting that misinterpretation of fluorescence behavior may occur if the concentration is too high.
Participants express varying viewpoints on the relationship between pH sensitivity in absorbance and fluorescence, with no consensus reached on whether fluorescein's fluorescence should inherently be pH sensitive or whether other factors may be influencing the observations.
Participants highlight potential limitations in their understanding of isosbestic points and the effects of concentration on fluorescence, indicating that further exploration and clarification are needed.
Bridget
Hi,
I have a quick question on fluorescence. I have fluorescein molecule. Its absorbance is pH sensitive. However, I want to know if
1. It emits fluorescence.
2. the fluorescence intensity pH sensitive
I know for sure it emits fluorescence. I see, what I believe to be an emission peak. However, I am not able to get any pH response. Irrespective of how acidic or basic I get, I am unable to get the intensity to change.
Can anyone explain this. Can we say by default that if a molecule has fluorescein in its structure, it should fluoresce? And, if it fluoresces, then it should be pH sensitive too, given, the absorbance is pH sensitive.
Thanks for your help.
Bridget said:
Hi,
Could you be more specific? What molecule is it and how are you adjusting the pH?
The molecule is fluorescein (sounds like a typo, but it is a commonly used fluorescent dye). Whether or not the absorption or emission peak intensity changes with pH depends on what wavelength/peak you are looking at. Fluorescein has an isosbestic point where the intensity of the peak at that point is independent of pH (other peaks still depend on pH). The reason why the isosbestic point is independent of pH is that both the conjugate base and conjugate acid have the same extinction coefficient at this point. It doesn't matter how much of one or the other you have at the isosbestic point (amounts determined by the pH), you will get an absorbance based on the total concentration only.
Thank you for the replies. When I say this molecules is fluorescein, I mean it has fluorescein in its structure. Its absorbance is a pH sensitive. This molecule does have an isobestic point for absorbance. In that case, would it mean it should have an isobestic point for fluorescence too? Only that I haven't come across any literature stating its fluorescent properties. I see an absolutely steady fluorescence for neat 0.01M NaOH and 0.01M HCl solutions. Absolutely no change whatsoever.
However, I am not sure I fully grasp the idea behind isobestic point. I did not come across this for any of the fluorophores I have worked with previously. Can you please tell me more about it...or guide me on where I can find more information on this.
Thank you for your help.
Does the molecule have more than one acid / base site?
What was the concentration of your solution? If the concentration is too high, you will see no change in apparent fluorescence. This is due to the strong absorption of the fluorophore. Did the solution appear to fluoresce from only the surface of the solution or did it appear that the entire cuvette glowed?
Beers law (and nonlinearities for Beers law) works for both absorbance and emission.
To either confirm or eliminate this as a possible cause, you need to look at the absorbance of serial dilutions of the tested solution at both the absorbance frequencies (one each for the protonated form and the deprotonated form) and the absorbance at the emission frequencies. The Beers law plot of the serial dilutions should be linear for all cases... if not you are observing the nonlinearity of the absorption/emission and misinterpreting it as the chormophore having no pH dependence.
