2 150kva generators feeding a 1200 amp service
  • Thread starter Thread starter Sparky1550
    Amp Generators
Two separate 150kVA 120/208 3-phase gas-powered generators can indeed feed a 1200 amp 3-phase AC electrical service, provided they are properly synchronized. Key considerations include ensuring that both generators maintain the same phase angle, voltage, and frequency to avoid operational issues. Additionally, potential harmonic distortion from separately derived systems must be evaluated to prevent voltage irregularities. Each phase voltage will remain at 120V when correctly combined, without resulting in 208V or 240V outputs.
  • Understanding of 3-phase AC electrical systems
  • Knowledge of generator synchronization techniques
  • Familiarity with harmonic distortion in electrical systems
  • Basic electrical engineering principles related to voltage and power factor
  • Research generator synchronization methods for parallel operation
  • Learn about harmonic distortion and its impact on electrical systems
  • Investigate the implications of power factor on generator performance
  • Explore voltage regulation techniques in 3-phase systems
Electrical engineers, power system designers, and technicians involved in generator installation and maintenance, particularly those working with 3-phase AC systems.
Sparky1550
Can I feed a 1200 amp 3phase AC electrical service with 2 separate 150kva power sources? (the sources being 150kva 120/208 3phase gas powered generators) Are there any issues with harmonics from separately derived systems? Will each phases voltage still be 120v or by combing 2 separately derived phases will the voltage become 208v or 240v etc?
What voltage is the service?
What is the power factor of the load?
If you use two generators in parallel, they must have the same phase angle, voltage, and frequency (or really close to it) before you parallel them.
CS
  • · Replies 18 ·
  • · Replies 47 ·
  • · Replies 16 ·
