Solve Two-Pulley Problem: Tensions, Forces & Diagrams
The discussion centers on solving a two-pulley problem involving a 10 lb weight and a 5 lb weight, where tensions T1, T2, T3, and T4 need to be determined. The key takeaway is that the tension in the rope remains constant throughout, and Newton's 2nd law must be applied to each mass to derive the equations needed for solving the system. The participant is encouraged to identify the forces acting on each mass and combine the resulting equations to find both the acceleration and the tensions in the rope segments.
  • Understanding of Newton's 2nd law of motion
  • Familiarity with tension in ropes and pulleys
  • Ability to draw and interpret force diagrams
  • Basic knowledge of vector forces and equilibrium
  • Learn how to apply Newton's 2nd law to systems of pulleys
  • Study the concept of tension in strings and ropes in physics
  • Explore how to create and analyze free-body diagrams
  • Investigate the effects of acceleration on tension in pulley systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of pulley systems and tension analysis.
scipioaffric
A pulley hangs from the ceiling. A string is run over the pulley and one end is attached to the ceiling, while a 10 lb weight hangs from the other end. In between the first pulley and the end of the string that is attacked to the ceiling rest another pulley on the string with a 5 lb weight hanging from it, as in the diagram below. Find the tensions of the various segments of string, in terms of applied force.
http://www.energeia.us/pulley1.png
T1= ?
T2= ?
T3= ?
T4= ?
W1= 10lbs.
W2= 5lbs.
This is the section I'm having the most trouble with. Which tensions are part of which system? Does T1+T2+T3=15pounds or 5 pounds, does T4 = the weight of the whole system, or only part of it?
I can't begin to solve the problem without being able to identify all the systems. Also, I'm not sure how to draw the force diagrams without the systems. Here are some things I think I know about the problem:
There is no normal force counteracting the weights from underneath. All normal forces will counteract the forces operating against them in the system that is suspended from them at the points attached to the ceiling.
so, we have Fn1 at the leftmost ceiling-mounted point, and Fn2 at the rightmost ceiling-mounted point. So, we have a force diagram for each of these with an N axis. The magnitude of the vector for normal force is given as the equal and opposite force of the system hanging from the string.
Other than this, the only thing I'm fairly sure of is that the 10lb weight exerts 10lbs of force downward on the right side of the ceiling mounted pulley, and 10lbs upward on the left side of the pulley.
Someone please help me out, this is the first problem I've seen like this. Thanks.
Well... not exactly. The 10lb weight would exert 10lbs of force on the rope if there were no acceleration, but that's not the case here. You have to solve for the tension in the rope.
Identify the forces acting on each mass and apply Newton's 2nd law. Combining the two equations (one for each mass) will allow you to solve for the acceleration and rope tension. Hint: The tension is the same throughout the rope.
  • · Replies 18 ·
  • · Replies 102 ·
9K
  • · Replies 22 ·
  • · Replies 34 ·
  • · Replies 30 ·
  • · Replies 18 ·
