Determine which points on graph of X = sqrt(Y) are closest to (0,3)
  • Thread starter Thread starter Hellsing834
    Graph Points
The problem involves determining which points on the graph of X = sqrt(Y) are closest to the point (0,3) and finding the minimum distance between these points and the graph. The context is rooted in geometry and calculus, particularly focusing on distance minimization and the interpretation of functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of the distance formula and the implications of the graph being represented as X = sqrt(Y). There are attempts to clarify the relationship between the coordinates and the graph's orientation. Some participants question the correctness of specific points identified as closest to (0,3) and explore the conditions for perpendicularity between the tangent line and the line connecting the points.
The discussion is active, with various interpretations being explored regarding the setup of the problem. Some participants provide insights into the geometric relationships involved, while others express uncertainty about the correctness of specific solutions. There is no explicit consensus on the correct answer, but several productive lines of reasoning have been presented.
Participants note the complexity of the problem due to the unconventional representation of the function and the coordinates involved. There is mention of potential confusion arising from the roles of the variables and the need to clarify the distance calculation process.
Hellsing834
Determine which points on graph of X = sqrt(Y) are closest to (0,3). What is the minimum distance between the point(s) found and the graph of x = sqrt(Y)
I used the distance formula.
I came up with (sqrt(2) , 2) but i hardly doubt its right because i have no clue what the question is asking, can somebody just tell me if my answer is right or not?
A quick confirmation check: if the point is the closest to (0,3) then the derivative of the graph at that point must be perpendicular to the line connecting the two points (in this case it is). So your answer is correct
It's wrong. The point you found isn't on the curve (but (2, sqrt(2)) is, though).
How did you use the distance formula? To use it, you need to have the coordinates of two points, one of which is the point on the curve that is the closest, and I don't see any work that shows that you found the closest point.
This problem is tricky because it gives x as a function of y, which is the opposite of how we're usually given it.
Here's what I did.
I drew a graph of x = sqrt(y). The vertical axis is the x axis, and the horiz. axis is the y axis. The graph looks exactly like that of y = sqrt(x), but the axes are labeled differently and all the points are (y, x) pairs.
Call the closest point on this graph P, with coordinates (y, sqrt(y)).
Find the slope of the function (namely, dx/dy). This will be dx/dy = 1/[2*sqrt(y)].
Find the slope of the line from P to the point B(0, 3) on the vertical (x) axis. The slope will be the result of delta x / delta y.
At the point on the curve that's closest to B, the tangent line at P will be perpendicular to the line segment OP. This means that their slopes will be negative reciprocals. This will give you an equation involving radicals that you can (maybe) solve. After moving things around and getting rid of the radicals in the denominators, I ended up with a cubic polynomial that I was able to factor into a linear factor and a quadratic factor. The quadratic had no real roots.
The point (2, sqrt(2)) (coordinates reversed from the one you reported) is about 2.55 units away from (0, 3). The point I found is about 2.236 units away, so is closer.
Hope this helps.
The trouble is, the point the OP found isn't on the graph of x = sqrt(y).
y=2. sqrt(y)=sqrt(2)=sqrt(2)=x. I assumed he was still writing his coordinates in (x,y) fashion
Wait so is my answer right or is Mark's answer right?
What i did is i solved for y, and i got Y = X^2. and then from there, i used the distance formula. (0,3) were my first points, my second points were (X,Y) then i knew that Y = X^2 so i plugged it into my distance equation, then i squared the sides and took the derivative. When i did that i got 0 = 3y-6 then i solved for Y, and it gave me 2.
Mark44 didn't give an answer. He described one way to get an answer. Your description of the method is roughly correct as well. But y=2 is quite wrong. Can you show us how you got that in detail?
As I mentioned before, this problem is tricky due to x being given as a function of y, and the point (0, 3) being given. For this point, 0 is a value of y and 3 is a value of x. y = x^2 (for x >= 0) is equivalent to the first equation, and its graph will look exactly the same as that of x = sqrt(y) using the same coordinate axes as before. However, if you switch the x and y axes, you're going to also have to switch the coordinates of the point on what was the vertical axis, so that it's now on the horizontal axis, and its new coordinates will be (3, 0).
x= sqrt(y) is the the right half of the parabola y= x^2. The (square of the) distance from the point (x, x^2) to (0, 3) is x^2+ (x^2- 3)^2. Minimize that and discard any negative solution for x. Looks lilke a pretty simple problem to me.
Since x is given as a function of y, I am interpreting this problem to mean that y is the independent variable and x is the dependent variable so that (0, 3) is a (y, x) pair. Certainly y = x^2 for x >= 0 is equivalent to x = sqrt(y), and their graphs are identical. If you relabel the axes, though by switching the roles of y and x, your new graph is the reflection across the line y = x of the original. In particular, the point (0, 3) is reflected to (3, 0).
You can minimize |(sqrt(y),y)-(0,3)| and find y. Or you minimize |(x,x^2)-(0,3)| and find x. Why 'rotate'? It just makes it easier to lose track of which variable is which. The real problem here is that the OP has gotten 0=3y-6 as an equation. I would like to know how.
You realize that if you have a pair (x,y) you can still graph x as a function of y? Considering the OP even stated that the coordinates are in the form (x,y) I think continuing to use it in (y,x) form is just being obstinate
I have qualified my answer in each post by saying what my assumptions are. If you were to graph a function given as b = f(p), you would probably put b on the vertical axis and p on the horizontal axis, the usual practice for dependent and independent variables.
There was nothing in the OP's original post that stated the meaning of the order in any ordered pairs. IMO, the problem could have been stated more simply by giving the function as y = x^2 for x >= 0. Then there would not have been any uncertainty on my part about whether the distance was measured from the curve (whatever it is) to either (0, 3) or (3, 0).
If my asssumption here is incorrect, I'll be happy to concede my argument.
If you are speaking of the graph of the graph of [tex]y = \sqrt x[/tex], and discussing ordered pairs on that graph, and in the plane, the order for the coordinates is [tex](x,y)[/tex], by convention. There is no requirement for the OP to specify which "specify which order is meant for ordered pairs."
An explanation of another why another approach is valid is perfectly fine, but saying the choice is "arbitrary" is not.
I'm a bit puzzled as to why this is still a problem. It is not too difficult to minimize the distance from [itex](\sqrt{y}, y)[/itex] to (0, 3). It is almost trivial to minimize the distance from [itex](x, x^2)[/itex] to (0, 3) and drop the negative x solution as I suggested before.
