Golf ball problem (2D Kinematics)
The problem involves a golf ball being chipped with an initial velocity of 20 m/s along a level fairway, focusing on determining the angle of projection that results in the maximum height being equal to the horizontal distance traveled. The context is rooted in 2D kinematics.
  • Participants discuss the relationship between horizontal and vertical motion, with attempts to express the distance and height in terms of time and initial velocities. There are questions about the necessary mathematical relationships and formulas needed to solve the problem.
Some participants have offered insights that may help clarify the relationships between the components of motion, particularly the ratio of vertical to horizontal velocity. There appears to be a productive exchange of ideas, with some participants expressing a need to further understand the provided hints.
Participants mention feeling challenged by the problem, indicating it is part of a set of difficult exercises. There is a sense of uncertainty regarding the necessary formulas and relationships to apply.
chudd88
A golf ball is chipped with an initial velocity of 20 m/s along a level fairway.
a) WHat angle should the initial velocity make with the horizontal for the maximum height to be equal to the horizontal distance on the fly?
b) What is this horizontal distance.
I've been working on this problem over the past couple of days, and I'm stuck on it. It's one of the problems at the end of the chapter, which are supposed to be the most challenging, but I feel like either there's some important mathematical formula I'm expected to remember, or there's something very simple I'm overlooking.
My attempts so far:
* The distance x at time t is the same as the height y at time t/2
* The initial horizontal and vertical velocities are 20*cos(theta) and 20*sin(theta) respectively.
* I've done every manner of substitution I can think of, converting values into corresponding values using all of the equations I have available to me. Either I come out with a totally wrong answer, or I just end up with an identity.
I understand the basics of 2D kinematics. If I knew the initial angle I'd be able to figure out everything about the ball's flight. But, trying to use what's available to me, and work it backwards to the angle, isn't working out for me. I keep wanting to get a value relative to cos(theta) or sin(theta), and use the pythagorean theorem to get one of the other initial velocities, but I'm just not getting there.
Could someone give me a hint as to what it's going to take to figure this out? I don't expect anyone to do the whole thing, but if you can see, looking at the problem, some bit of insight I'm obviously missing, that would be very helpful.
Thanks.
My attempts so far:
Try this:
t * Vx = x or Vx = X/T where T is the total time and X is total Distance which is also height.
We also know that X = 1/2*g* (T/2)2
(T/2 because what goes down must have gone up.)
Substituting then we know Vx = (1/2 * g * T2/4) / T = 1/8 * g * T
Now you also know that Vy = g * T/2
The ratio of Vy/Vx = Tanθ
Thank you for the help. I need to go over your work a bit more to understand it, but I can see it leading me to the answer. The greatest help was in your statement:
I realize that should have been obvious to me, but I just wasn't seeing it. That was the "insight" I needed to relate all the pieces together.
Thank you again.
Thank you again.
Happy to help.
Cheers.
  • · Replies 19 ·
  • · Replies 21 ·
